Old July 18th, 2017, 11:45   #31
relumalutan
relumalutan's Avatar
Good job on the bracket JETaah. Maybe you can give us some details so I can make one for my car. I remember when you've fixed my failing hood insulation using welding wire. Simple but ingenious!
relumalutan is online now   Reply With Quote
Old July 21st, 2017, 08:25   #32
bherman13
Originally Posted by Henrick View Post
Everything wears out. PD is a wear engine on everything - be it cams, egr coolers, DMFs, injectors, cylinder heads or even intercooler hose clips and hoses themselves.
At that mileage you might have wear on injector bores on the cyl head. Worth checking.
Injectors typically last a bit longer but it's not uncommon to see a work injector or two at that miles also.
I'm not familiar with this problem. How does one go about checking this?
bherman13 is offline   Reply With Quote
Old July 21st, 2017, 10:57   #33
Henrick
If you don't have fuel to oil dillution, don't get in there.
The injectors are fixed on one side, using one bolt. They rock back and forth once being pressed down in their bore.
Over time and miles, the bores wear out. Visual inspection shows sharp and/or worn edges.
As a remedy for that, these bores can be sleeved. I have seen a few cylinder heads with sleeved bores. However, I didn't find any shop locally which would be offering such service. But hey, I don't own a PD and I don't have such a problem...
Henrick is online now   Reply With Quote
Old July 24th, 2017, 07:28   #34
bherman13
Does the fuel get in the oil with that problem? Or does the oil get in the fuel?
Old July 24th, 2017, 11:18   #35
Henrick
Fuel gets into oil.
Depending on the wear, oil level rises.
Worst what I have seen is about 3 inches over the MAX mark in a few days.
Old July 25th, 2017, 13:10   #36
bherman13
Wow that's some pretty bad oil dilution.
Fortunately, mine's at least minor if not non-existent. The oil level has never risen noticeably.
Intake manifold gunk? Noodle138 VW MKIV-A4 TDIs (VE and PD) 3 April 6th, 2005 11:28
Intake manifold gunk BoboBear VW MKIV-A4 TDIs (VE and PD) 6 March 23rd, 2005 15:28
gunk in the intake manifold? 00 Jetta VW MKIV-A4 TDIs (VE and PD) 3 June 1st, 2004 16:02
Clogged Intake Manifold! runaway231 VW MKIV-A4 TDIs (VE and PD) 7 April 30th, 2002 14:44
clogged intake manifold Rob Winterkorn VW MKIV-A4 TDIs (VE and PD) 30 November 18th, 2000 17:02
Page generated in 0.16375 seconds with 12 queries
[Output: 74.05 Kb. compressed to 64.87 Kb. by saving 9.18 Kb. (12.40%)]
