Old July 15th, 2017, 16:08   #1
moorsb
TDI(s): 2015 Passat
Default AD Blue
2015 TDI is there no light or indicator if you are low? I have 2100 miles and I had t fill it I think it was empty.
moorsb is offline   Reply With Quote
Old July 15th, 2017, 16:11   #2
ZippyNH
There is a low level light, and a count-down till the car cannot be started.
ZippyNH is offline   Reply With Quote
Old July 15th, 2017, 16:14   #3
ZippyNH
Tip...if you find truck stop or gas station that has DEF pump at the island, it will usually cost about $5...
Pumps charge about $2.29 a gallon for DEF.
Old July 15th, 2017, 18:05   #4
Rico567
I just add a 2.5 gal. jug when I do the 10K oil change. On our (unfixed) 2013, I think that'll keep it topped up, from what I've read. For the 2015s, that may be another question, and I think it's reasonable from what I've read about it that all the fixed Gen 2 and Gen 3 cars are going to be using more....but it'll probably be a while before it'll be possible to get a handle on an average consumption.
"I reject your reality and substitute my own."
- Adam Savage
Rico567 is offline   Reply With Quote
Old July 17th, 2017, 04:55   #5
ilyago
My 2015 Passat uses about 2 gal for about every 11 K miles. When the "Add AdBlue" message comes on, I just add 2 gallons.
Why top it off? It is not a gas tank. This way, I always have fresh AdBlue in the tank, don't spill any extra fluid, and don't have to store any partial bottles of AdBlue.
The 1500 miles warning gives me plenty of time to go to Walmart and pick up a 2 gallon jug.
-Ilya
2015 Jetta TDI S DSG
2015 Passat TDI SE manual
2010 JSW TDI 6-sp manual - SOLD in 2015
1998 Jetta TDI 5-sp manual - SOLD in 2010
ilyago is offline   Reply With Quote
Old July 17th, 2017, 07:03   #6
Blue_Hen_TDI
I did an extrapolation calculation of usage on mine (2015 Phase 1 fixed new old stock) based on some early topping off. Mine looks to be on pace to use ~1.67 gal per 10k miles.
My driving is nearly 100% highway. I don't use the car for short trips. It's regenerating every 250 miles like clockwork as well.
2016 GTI S 6M with Performance and Lighting Packages and a few mods
Blue_Hen_TDI is offline   Reply With Quote
Old July 17th, 2017, 08:18   #7
Jetta_Pilot
Jetta_Pilot's Avatar
Location: West Hill, Ont. Mexico mid October 2017 to end of April 2018
Just to clarify. You need to bring your own container, you do not fill the DEF tank from the pump.
As has been mentioned by a couple of others, I also use about 1 liter ( 1 quart) per 1,600km (1,000 miles).
All interior bulbs to LED. Several VCDS modifications. Darker window tint. EVO skid-plate. Malone Stage 2, Winpower Projector headlights. Angel eyes.LED DRL's.Average 1 year 30/6/16 to 30/6/17 - 50.71 Mpg - 5.56 L/h
Old July 17th, 2017, 11:35   #8
Rico567
And I add mine when I change oil, works out about the same. To each his own, so long as the SCR system gets fed.
- Adam Savage
Old July 17th, 2017, 18:05   #9
ZippyNH
No...
Straight into the tank.
NO CONTAINER NEEDED.
Just hold a clean rag over the end of the hose as you lower it and lift it to prevent drips.
Then fill away.
2015 Jetta TDI SE, Silk Blue
previous-2005 MINI Cooper S, tuned and modded to 200+ HP
Old July 19th, 2017, 04:40   #10
740GLE
Just don't try and brim it to the top, its gotta be hard to hear and see when you're getting close.
I believe when the warning comes you can fill with 4-5 gallons, pay for 3-4 gallons and call it good.
That being said, I've always brought my own container, used jugs, as I'm rarely driving the wife's car buy a truck stop when it's needed.
740GLE is online now   Reply With Quote
Ad blue question medobson1 VW Touareg TDIs 7 December 13th, 2014 10:51
Ad Blue safe mode single94 VW Passat Family (NMS and B7) TDIs (2012+) 26 October 30th, 2014 04:06
Jetta TDI with AD Blue????? considering a tdi TDI 101 2 May 14th, 2013 18:34
Which is better: DPF or AD Blue? FormerOwner TDI (Diesel) Emissions 57 January 19th, 2012 08:51
Ad Blue ekkoh99 VW Touareg TDIs 20 August 2nd, 2011 16:25
Page generated in 0.16847 seconds with 12 queries
[Output: 95.94 Kb. compressed to 81.36 Kb. by saving 14.58 Kb. (15.20%)]
