Old July 15th, 2017, 15:20   #1
Schoust
Default Mk4 Bew Engine in a Mk5 Brm
I posted this up in the mk4 forum but thought I would try it here. I have a 05 Mk4 Bew engine that I would like to use in place of Mk5 Jetta Brm engine that has been destroyed do to the lack of maintainance. Will it work? If so what would need to be done to make it work? Is it worth it?
Schoust is offline   Reply With Quote
Old July 15th, 2017, 16:41   #2
Rembrant
Rembrant's Avatar
Fuel Economy: 50 MPG.
Somebody posted one of those swaps on here not all that long ago.
I know nothing about it, but it apparently has been done...at least once.
http://forums.tdiclub.com/showthread.php?t=475323
2006 White Jetta BRM TDI 5spd w/Black Leather.
2011 Black Lexus IS250 AWD. My wife's, the high roller.
1984 Ford F150 Stepside project. Old school 3 on the tree.
Rembrant is online now   Reply With Quote
Old July 16th, 2017, 07:45   #3
turbocharged798
turbocharged798's Avatar
Fuel Economy: 40-50mpg
I would be much easier to do a valve job on the BRM that is in the car now. Block can stay in the car too.
99.5 Black Jetta TDI; DLC1019 nozzles, G60/VR6, ASV .5mm pistons, EGR delete, ASR/EDL, bilstein TCs MFA cluster.. Beater car. 365K miles and climbing.
99.5 Red Jetta TDI. Saved from the crusher. 270K
04 Jetta TDI .MFA cluster, reverse light mod, bilstein TCs 200K.
turbocharged798 is offline   Reply With Quote
Old July 16th, 2017, 11:34   #4
Henrick
Typically repairs and labour to repair an engine cost way more than a used/healty engine intact.
I have seen similar swaps. From the interesting ones I recall a 1.9 TDI-PD engine swap in place of 2.5 R5 TDI on a VW Transporter T5 as well as Mercedes-Benz engine into VW Crafter.
Henrick is online now   Reply With Quote
Old July 16th, 2017, 13:16   #5
Schoust
Well honestly that was my thought exactly! I have a perfectly healthy BEW engine from my son's totalled mk4 wagon that I thought would work since these engines are close in tech.
But I'm not getting any feed back at all as to if it's a tough or expensive ordeal.
Of course a valve job is easy and no doubt the preferred route if the engine had low miles, it does not.
So my thought was simply swap the two out....
I'm begining to think it's not worth the aggravation and unless I can find something or someone to tell me otherwise it looks like I'll soon have a nice healthy BEW engine for sale soon... ....
Old July 16th, 2017, 18:21   #6
turbocharged798
Well they share almost no parts so everything is different, crank sensor is different, oil filter is different, ect. Could you jerry rig something together and make it work, probably. Is it easier than doing a valve job? Probably not.
Old July 17th, 2017, 10:03   #7
bobthefarmer
SO, lets be clear here. An engine is a system. It is not just something that fits in a hole and work autonomously. You can't just lift out a BRM and stuff in a BEW, no matter if they fit in the hole. You need to adapt a harness, change the EEC, and work out other differences between computers which "Drive" the car. I take turbocharged798 advise as simple wisdom.
Have at it! I would not waste my time.
bobthefarmer is offline   Reply With Quote
Old July 18th, 2017, 16:57   #8
Schoust
I simply asked the feasibility. If it's not a feasible project and not cost efficient I won't do it. I thought this is what a forum such as this is for. I am only Familiar with the ALH and Bew platforms and not the Brm. I thought I would ask if it was doable.
It's obviously is not a practical project. Believe me though Bob if I had my mind set on this I would simply jump in a fab what isn't available.
Thanks all.
Mk4 Bew in place of a Mk5 Brm Schoust VW MKIV-A4 TDIs (VE and PD) 2 July 16th, 2017 19:04
Mk5 BRM vrs Mk4 ALH Grussing VW MKV-A5 Golf/Jettas 13 December 18th, 2014 12:16
WTB: MK5 BRM Engine / Parts chuckiet3 Private TDI Items for Sale/Wanted 0 July 28th, 2014 08:04
fs complet BRM Tdi engine ,and BEW engine parts adphil Private TDI Items for Sale/Wanted 16 July 22nd, 2012 11:52
Page generated in 0.14806 seconds with 12 queries
[Output: 84.54 Kb. compressed to 72.69 Kb. by saving 11.85 Kb. (14.02%)]
