Old July 17th, 2017, 05:31   #76
jokila
jokila's Avatar
Fuel Economy: 52/45/40
Is it needed in every tank? I find carrying the bottle of Power Service messy to deal with and hard to measure accurately from the bottle.
I guess I could keep it at home and remember to use it, but wonder if anyone has a good solution for the measure. If I could find a way to carry individual pours in the trunk that won't leak from the container I would be happy camper.
Ventecomy | Heated seat lighted switch | W8 light |
Blue tint aspherical tinted mirrors | Turn signal convenience | Euro Light Switch | Rear Fog Light | DrawTite Hitch | HIDs | 520 injectors | Engine Cover mod light |
VCDS-HEX/CAN & VagTacho available Houston metro area.
jokila is online now   Reply With Quote
Old July 17th, 2017, 07:54   #77
maxmoo
I carry a 1 liter bottle of additive and a clean empty 500ml water bottle in a heavy duty zip lock bag, stored in the little cuby hole with the rubber strap in the trunk.
I use the water bottle, with a permanent marker line at 100cc, as a measuring cup and to pour the additive into the tank.
That way it is always with me and no stink and no spill.
maxmoo is online now   Reply With Quote
Old July 17th, 2017, 08:53   #78
BobnOH
Fuel Economy: 50/45/35
I fill an small olive oil bottle with 4 oz. and carry just when needed. Last week I went 800 miles, took 2 pre-measured bottles.
Old July 17th, 2017, 09:30   #79
Genesis
Fuel Economy: 53/48/42
Just stick a bottle in the trunk near the spare tire, and a funnel. Put "some" in when you fill, before the fuel goes in.
Quantity isn't all THAT important with this stuff, and there's no cost to "too much" other than to your wallet. It's inexpensive enough that frankly I don't get the point in trying to be too cute with the quantity.
I've run this stuff in boats and land vehicles for quite a long time and I like it -- it's inexpensive, available anywhere (including at Wally!) and works. Use the gray stuff during the summer and white in the winter (if you're in an area where temps go materially below freezing; if gel risk is not at issue where you are then use gray all the time.)
Genesis is online now   Reply With Quote
Old July 17th, 2017, 13:13   #80
UhOh
UhOh's Avatar
I'm no way an advocate of biofuels, but I'm wondering if periodic use of biodiesel would also help. Biodiesel is known to clean out crap from fuel system, maybe it also cleans up injectors a bit?
UhOh is offline   Reply With Quote
Cylinder compression tester/adaptor tdi54 VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 1 September 16th, 2015 18:06
Another need for advice. Cylinder # 4, no compression. invader VW MKV-A5 Golf/Jettas 1 March 29th, 2014 10:30
What is 'normal' cylinder compression on an ALH? DougInFL VW MKIV-A4 TDIs (VE and PD) 16 February 11th, 2014 10:08
Cylinder Compression Specs for CBAA GraniteRooster VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 30 June 9th, 2013 18:08
Cylinder Compression Monitoring via VCDS? physicshogon VW Passat Family (NMS and B7) TDIs (2012+) 0 December 31st, 2011 15:16
Page generated in 0.13444 seconds with 12 queries
[Output: 72.05 Kb. compressed to 64.06 Kb. by saving 8.00 Kb. (11.10%)]
