Old July 11th, 2017, 10:36   #1
DZLBRNR
Default Trip Odometer and clock resets when iignition switch is turned off..
Has anyone had this issue that when the ignition switch is turned off, the trip odometer and clock resets back to zero and 12:00(respectively).
Also, the fuel gauge, temp gauge, and Tach needles remain in the position where they were as if the car was still on. And the radio has to be turned off manually.
I have checked to grounds under the battery. I am thinking ignition switch?
Any suggestions are appreciated..
DZLBRNR is offline   Reply With Quote
Old July 12th, 2017, 19:38   #2
eddieleephd
Fuel Economy: 45-51.9
I think you either have a bad ignition switch, or a short.
First thought reading odometer and clock reset I thought bad battery.
Weird electrical gremlin?...
2003 Jetta Wagon Alh w/5spd swap, 11mm IP, VNT17, Malone stage4 tune, BMW Cyclonic CCV filter, 2" lift
eddieleephd is offline   Reply With Quote
Old July 17th, 2017, 05:51   #3
jasonTDI
jasonTDI's Avatar
Fuel Economy: 13.7 c, 12-15 towing hwy. 17-19
Bad ignition switch.
Jason, Service work available. www.jasonTDR.com
Give a hand,www.akitas.org
jasonTDI is offline   Reply With Quote
Old July 17th, 2017, 06:43   #4
SilverGhost
SilverGhost's Avatar
Also check both battery and switched fused power to cluster are good. Sounds like the cluster is not receiving 30 (battery) power, but is receiving 15 (ignition) power. So every time you turn the ignition off it's like you disconnected the battery.
15 power is fuse S11 and is a 10A.
30 power is fuse S15 and is a 10A.
Both fuses are the smaller of the two in the end of the dash.
Could also be a bad ignition switch. What else is not working right?
Jason
SilverGhost is online now   Reply With Quote
Old July 17th, 2017, 12:16   #5
DZLBRNR
Thanks Jason, the fuses are all good. That was the first thing I check when it started happening. So it must be the ign. switch... Thanks for the feedback...
Lane
Trip Odometer and clock resets when iignition switch is turned off.. DZLBRNR VW MKIV-A4 TDIs (VE and PD) 2 June 18th, 2015 13:08
'03 wagon shuts down and resets clock and trip odometer wncre8r VW MKIV-A4 TDIs (VE and PD) 11 September 29th, 2013 09:27
Trip odometer resets to zero and clock to 12:00 at each start dennisy TDI 101 3 November 6th, 2009 10:08
Help, Odometer, trip odometer and clock blank and run car MadDogBrenner TDI 101 2 February 19th, 2009 15:33
Clock & Trip Odometer Resets freedom3 TDI 101 11 February 23rd, 2004 14:39
Page generated in 0.15922 seconds with 12 queries
[Output: 68.21 Kb. compressed to 60.36 Kb. by saving 7.85 Kb. (11.51%)]
