Old August 11th, 2017, 14:03   #196
All Stock
TDI(s): AHU
That's a copy and paste from his corvette conversion post.
Funny thing...maybe doing all this "wasted time" of work equals bonding time and memories with those who you do it with....
Funny thing my Mom just wrapped up her 5th round of cancer... all different types... rare they say... and now its been 30 years worth of it... she never had that attitude... The only one is her claim on my conversion and her desires to see it back on the road so she can enjoy it.
Hmm.. kinda makes it all worth it to me!
OEM's build for the masses. What we do is make something unique, one off. I don't want to be remembered as one of a million.... I want to be one in a million!
Jeep Wrangler TDI Hybrid...
All Stock is offline   Reply With Quote
Old August 11th, 2017, 14:09   #197
h4vok
h4vok's Avatar
I noticed it on that post too and I was going to call him on it here, but I didn't want to be that guy. The things you learn and people you meet along the way doing some of these projects is priceless. Also the feeling of accomplishment when you sort something on your list of things to fix is nice too.
DLC520, Mufflerectomy, Self tuned MPPSv16, more linked below
My car thread
h4vok is offline   Reply With Quote
Old August 11th, 2017, 14:44   #198
GTiTDi
Macht Schnell! Vendor
GTiTDi's Avatar
Location: 3 Spruce st Wareham, gateway to Cape Cod Massachusetts
Originally Posted by john.jackson9213 View Post
Lot's of wisdom in the above. My better half keeps telling me just go buy a new car and have fun. But I tell her I do like puttering with this car crap. The kids are very much into their own stuff. Still, a whole lot of wisdom in the above post.
wisdom? more like whizzz dumb
91 GTI CJAA (was 1Z powered) (2012 TDIfest Radical class winner) CTN+(eurotuning 6th) fully deleted, 3" SS downpipe and side pipe running standalone using the Tischspiegel
MK2 GTI build
schnellsnailFB
schnellvw.com
GTiTDi is offline   Reply With Quote
Old August 11th, 2017, 19:22   #199
Motohead1
Originally Posted by timmyc4 View Post
I used to be into doing all this B.S.
I got Terminal Cancer, am almost beating it and have LEARNED that this is a WASTE of time!
Life is short when you realize that this is all junk and the time you stick into it.
Buy yourself a nice 4x4 Manual Diesel Ford or Dodge or Chev for that matter with low miles or rebuilt. Nope you won't get the fuel economy, but on the other hand, you'll have reliability, durability and a GREAT puller, which you won't get with a pip squeak TDI in a vehicle it was NEVER desined for. I've had many TDI's... GREAT for what they were DESIGNED FOR! Buy something off the shelf so you can work on it or something some FOOL aready wasted his time doing!
Forget about this CUSTOM waste of time headaches and go have fun with your family. Spend your time fishing, playing with them. This is a waste of your valuable life.
You only have a limited time here, don't waste it on chasing the wind.
The fact is we are all dying. Happens 150,000 times a day around this sin cursed world. But those that have ears to hear know that eternity starts now. No need to put your hope in time.
I will pray for your complete healing friend. 2 Corinthians 4:16-18
Motohead1 is offline   Reply With Quote
Old August 11th, 2017, 19:26   #200
Motohead1
ok back on topic. White/orange needed a 2 ohm resistor and I now have a VSS signal. WOOT!
No I didnt leave it that way.
Also put some rear load help shocks on.
I hope to get the cruise stalk wired up in the morning.
Old August 11th, 2017, 20:03   #201
All Stock
TDI(s): AHU
Amen.
Old August 11th, 2017, 20:06   #202
jimbote
jimbote's Avatar
very nice! ... how'd you figure out it needed a resistor in series ?
jimbote is online now   Reply With Quote
Old August 11th, 2017, 21:27   #203
Motohead1
After staring at the wire diagrams metering the white/orange signal value at idle in first gear and knowing that the dodge speedometer and all the gauges send a test pulse (seen as a gauge sweep or bump) with key on I was thinking it could be seeing a ground at pin 20/121 on power up. So I guessed putting just a small resistance there would let the cluster computer be happy with its power on test. A smaller value resister would probably work to its just the first one I tried and it was spot on so I stayed with it.
Old August 12th, 2017, 18:15   #204
Motohead1
We got cruise control finally! I ended up using a 40amp 5 pin relay to simulate the VW brake switch. Took a while to figure out today as my automatic ECU needed a pin put in for the clutch switch. That was the easy part but long story short I never could get the bit in VCDS to actuate the clutch switch. I thought for sure my tune was flashed as a 5 speed but perhaps not. I used the pin2 white/tan on the dodge brake switch to run the relay and I also put it under the hood so I dont have to hear it. VW cruise stalk is upside down but the rh side gave more room and is the best location.
It works great save for one issue. When I tap the res button to add a mph or two its extremely aggressive. like 3/4 throttle instant to gain 1mph. Im wondering if this is part of the tune and it thinking its an automatic. Also I might change the resistor as the VW ecu thinks it going 15 or so mph faster. Not a problem as long as I dont hit a limiter.
Do you guys with alh swaps have this issue? Perhaps there is coding that can be added to give it a time span to achieve the requested speed?
Old August 12th, 2017, 21:21   #205
jimbote
jimbote's Avatar
try changing the coding to alter the pulses per mile ... change to the maximum ppm coding will allow, this should slow down the measured speed in vcds and might help the gain sensitivity on your cruise
i just realized this ^^ will only work if you're running the stock vw cluster... you're probably going to need a dakota digital converter to fine tune the ppm
Old Today, 18:06   #206
Motohead1
Thank God I have friends with a lift. Nothing like a 20min muffler install.
Finally put a muffler on this thing. Its a Magnaflow 12616. Absolutely killed any and all drone on the hwy. All you hear now is diesel rattle and a little bit of turbo spool. Its straight through so EGTs didnt go up at all. Its ready for long family trips now.
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
2000 dodge dakota quad cab 4x4 with tdi jetmoto3 Private TDI Items for Sale/Wanted 6 October 26th, 2015 11:36
FS: Dodge Dakota 2.5L Bellhousing Kriesel Private TDI Items for Sale/Wanted 1 April 12th, 2010 10:05
WTT: My 99 Dodge Dakota for a TDI. Smola67 TDI Cars for Sale/Wanted 1 June 13th, 2007 02:25
1999 Dodge Ram 3500 Quad Cab SLT, Cummins Diesel Dieselworld TDI Cars for Sale/Wanted 2 March 23rd, 2005 19:31
1998 Dodge Ram 2500 24v Cummins Turbo Diesel Quad Dieselworld TDI Cars for Sale/Wanted 10 March 7th, 2005 10:22
Page generated in 0.12769 seconds with 12 queries
[Output: 109.85 Kb. compressed to 93.63 Kb. by saving 16.22 Kb. (14.77%)]
