Old August 13th, 2017, 06:23   #1
turbocharged798
turbocharged798's Avatar
Fuel Economy: 40-50mpg
Default Unraveling the MK4 lamp mystery (cross reference chart)
Figured I would share this chart I made, this came about because finding proper MK4 replacement lamps can be difficult. And as we know, these cars always need replacements. So I sat down and started doing research. It turns out that for whatever reason VW engineers decided to use really short life lamps, like 300 hours is typical. I am guessing it has to due with euro efficiency laws because short life lamps are usually more efficient. Reality is that its not going to make a hill of beans difference and will likely cost you in fix-it tickets.
I used some PLT branded lamps from 1000 bulbs in the chart because it was what I could find at a reasonable price. I found a lot of them can be safely interchanged with common American (ie: 1156) with no issues. You also will have the benefit of a much longer life and cheap replacements readily available.
Use the chart at your own risk. There might be errors, typos, or mistakes. If you see something that looks wrong, please point it out. Thanks.
99.5 Black Jetta TDI; DLC1019 nozzles, G60/VR6, ASV .5mm pistons, EGR delete, ASR/EDL, bilstein TCs MFA cluster.. Beater car. 365K miles and climbing.
99.5 Red Jetta TDI. Saved from the crusher. 270K
04 Jetta TDI .MFA cluster, reverse light mod, bilstein TCs 200K.
turbocharged798 is offline   Reply With Quote
Old August 13th, 2017, 10:10   #2
wonneber
I've used 194 (or 194A) for the 2825/168
Got a few boxes of those I have to use before I buy more.
wonneber is offline   Reply With Quote
Old August 13th, 2017, 13:40   #3
Oo-v-oO
Oo-v-oO's Avatar
I ran across this page recently, which offers an opposing viewpoint. FWIW...
https://www.matthewsvolvosite.com/fo...ic.php?t=61483
But for the amber bulbs you list such as line #15 and #17, add the suffix "NA" for Natural Amber bulbs.
-Lee
"Felix qui potuit rerum cognoscere causas"
[Happiness is understanding how things work]
Oo-v-oO is offline   Reply With Quote
Glow plug cross reference Diesel_Rabbit TDI 101 3 November 7th, 2010 20:17
Cross reference for OBDII Lefty TDI 101 3 November 7th, 2009 11:18
Transmission cross reference Silentone TDI 101 0 February 22nd, 2008 08:27
Parts cross reference vw2005tdi TDI 101 0 February 16th, 2007 11:50
Euro Lamp Bulb X-Reference comsult VW MKIV-A4 TDIs (VE and PD) 1 March 25th, 2004 11:26
Page generated in 0.11330 seconds with 12 queries
[Output: 58.84 Kb. compressed to 53.43 Kb. by saving 5.41 Kb. (9.20%)]
