Old August 4th, 2017, 06:51   #1
Jfritz33
Default 1990 Toyota pick 98 M-TDI swap need some help
First time posting on this site so be patient with me. Decided about two years ago to ditch the 22re due to lack of power and too many electronics to deal with. Sold the motor and purchased a 1998 1.9L TDI. Did a lot of research and went mechanical and swapped pumps, acme adapters swap kit, bigger injectors, new turbo, front mount intercooler, EGR delete, custom 2.5" exhaust, and a hole bunch of new parts to make the swap work. I have the motor in, and running, I am hung up on the throttle cable. It is way too long and haven't figured out how to make it work. If anyone that has done this swap can give me some ideas and pictures to make it work would be great. I could take it to a shop but I'm trying to save money, the swap wasn't cheap.
Jfritz33 is offline   Reply With Quote
Old August 13th, 2017, 06:57   #2
samuraitd
samuraitd's Avatar
For my MTDI samurai, I took a VW mk2 diesel throttle cable, cut the pedal end off, then made a pin with a set screw that fits into the pedal assembly. I have no idea what a Toyota pedal looks like, but I'd imagine it's probably similar.
1986 Samurai MTDI swapped
1991 Jetta "fr"Ecodiesel
1987 Samurai AHU swapped
samuraitd is offline   Reply With Quote
Old August 13th, 2017, 08:16   #3
ronnierider
Fuel Economy: 33 mpg combined
I reused the Toyota cable, shortened it and made a fitting that pinches the cable. I'll try to get pics, but essentially a bolt that goes through the pump's plate with a hole for the cable pinched with 2 nuts would do the trick. 100,000 kms on my swap now and it's been trouble free.
ronnierider is offline   Reply With Quote
Another Ranger/Mazda pick up TDi swap Jerz TDI Conversions 26 March 5th, 2016 07:16
1990 Toyota pickup from AAZ to AHU MTDI djtc TDI Conversions 83 February 17th, 2015 16:48
1990 Toyota 22RE 4x4 Engine Swap LukeWilson TDI Conversions 212 October 16th, 2012 20:18
FS 1990 jetta with ALH90 tdi swap tdipower4me TDI Cars for Sale/Wanted 15 March 29th, 2009 11:03
1990 Toyota ext cab sr5 efi turbo diesel 4x4 auto Dieseltoys TDI Cars for Sale/Wanted 6 May 13th, 2006 05:58
Page generated in 0.13265 seconds with 12 queries
[Output: 57.51 Kb. compressed to 52.26 Kb. by saving 5.25 Kb. (9.14%)]
