lakhotaspirit
After searching the forums I only found 4 topics of which one involved MODS. Below are postings from these topics:
Have them replace the glow plug relay. A blinking glow plug light WITHOUT a Check Engine light indicates a problem with the glow plug system. WITH a Check Engine light would indicate that a malfunction has been detected and a "stored" fault code can be found in the ECU memory. (As opposed to a "pending" code, which just means that the ECU has detected a possible problem and is looking for "confirmation" before it starts flashing lights. "Pending" codes can be read with a scan tool, but no warning is given to the driver.)
I made it home and it didn't blink! The service advisor didn't give me the right story. It says here on the "invoice" that the brake light switch was intermittent (using scan tool found a sporadic code 00741-brake light switch) and the switch was replaced, problem solved...so far. I wonder why only 0.71 labor on the invioce? Can they only charge VW a flat rate to change out the switch, and not charge for troubleshooting time? Anyway, for those interested, the part number of the switch is 1J0-945-511-A.
In this case, it was a brake light switch. As mickey said later, the lights are for emission controls, and not for diagnosing problems. Then I was reading the other story:
Got my car back from VW last evening, and am no more educated than I was last week. All they could tell me was that "something" was wrong with the Diesel injection pump, and so they replaced it. Couldn't tell me anything of the nature of the problem, since they just replaced the part without exploring the situation further.
In this story many mentioned about draining the fuel filter to get the lights to shut off. And now is my full story. 1998 NewBettle 41,000. Bought used at 38,500. At first I noticed the tripometer would reset without me hitting the button. Then one day the radio went into safe mode, and the CEL came on. I did the fuel cap magic, and checked the oil, and filled up with amoco premium blend, and threw in some powerservice. The CEL went away for about 300-500 miles. Two weeks ago, the CEL came on and stays on after you start the car, and it idles for a minute or so. Now today, driving down the road, shortly after the blue temperature light went out, the glow plug light started to blink. These stories have only given me one priority, that is to drain the filter as soon as I get back to me car. However, it may be the Glow Plug Relay from what is said in the FAQ. Now I checked the metal fuse on the battery and that is ok, but where the hell is the GLOW PLUG RELAY? The one fuse box is on the left side of the dash, in which you can only get to it if the driver side door is open. Where is the other fuse panel?
That is one question (cause the bentley is not clear on the location). The other thing is about the fact if my BATTERY could cause the problem. With my power loss problems, it was recommeneded to check the wire harness for coolent (where is the harness??) and check the battery. I have been reluctant to disconnect the battery because of these other problems and what happens to the resulting codes. So I hope this is enough info, here are my questions
Where is the other fuse panel where the Glow plug relay resides?
Is draining the fuel filter the miracle cure for the blinking glow plug light. Should I go ahead and disconnect the battery and test it even though all these other things are going wrong and it may/or may not(dont know) reset the trouble codes??
