2010golf
Wife got home today . About 2 hrs later I noticed a loud noise comeing from the garage . Car's Cooling fan was ripping at 100 percent . It will run for 1 minute then shut off for 15 seconds then repeat . If I open or shut a door it shuts off for 30 seconds or so then ramps up again . It will continue this for hours intill the battery dies. As soon as I turn on ignition fans shut off and do not restart intill ignition is turned off again. I have scanned with vcds ..sensor temp values look reasonable..no fault codes. Somewhat limited because vcds only works with ignition on and fans only run when it is off. Any Advice greatly appreciated.
