Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > Non VW Group Diesels
Non VW Group Diesels This section is for discusion of Non VWGroup Diesels.
Old December 26th, 2016, 14:30   #1651
k1xv
k1xv's Avatar
The Mazda diesel will get here when Lucy lets Charlie Brown kick the football.
09 TDI Sedan DSG with 17" Khartoum dark silver wheels, sunroof, Platinum Gray exterior, Anthricite interior, Built 11-08
acquired from Chris Farnham "3193" under CARS program. RIP Chris.
k1xv is offline   Reply With Quote
Old December 26th, 2016, 15:38   #1652
bhtooefr
ToofTek Inventor
bhtooefr's Avatar
TDI(s): None
So, August 2, 1979?
(She did let him kick the football... but he missed and kicked her instead.)
The really cool ToofTek made "Emperor's Clothes" injector fork risers only worked until someone pointed out that there wasn't any thing there.
bhtooefr is online now   Reply With Quote
Old January 24th, 2017, 04:11   #1653
Ted Hurst
Ted Hurst's Avatar
TDI(s): 2015 GSW
Fuel Economy: 42
Originally Posted by GoFaster View Post
I've read elsewhere that Mazda is already working on 2nd-generation Skyactiv gasoline engines, which will be using HCCI. At that point, there pretty much ceases to be a distinction between a gasoline engine and a diesel engine. They may just opt to skip the diesel for the current generation since the next generation would render it redundant anyhow.
This is encouraging:
http://www.greencarreports.com/news/...gine-next-year
'15 White GSW 6M TDI S
'12 Candy White JSW 6M, 80k mi, Stock - Let VW Buyback.
'09 Reflex Silver JSW DSG, 63,500 - Rust colored coolant - Traded for above 2012 JSW
'06 Black Jetta DSG Special Edition, 138k Mi, Frost Heater, RC1+,HEX-CAN USB - Traded
Ted Hurst is offline   Reply With Quote
Old January 24th, 2017, 16:23   #1654
tikal
Fuel Economy: 37 MPG (~ 45% city)
Originally Posted by Ted Hurst View Post
How will be the torque as compared to the current Mazda gasoline engines?
tikal is offline   Reply With Quote
Old January 24th, 2017, 17:26   #1655
RabbitGTI
RabbitGTI's Avatar
Fuel Economy: Don't know. I just feed it and drive.
I suspect there will be slightly more torque until it blows up. Then there will be significantly less.
Rabbit GTI racecar RIP, 84 Rabbit GTI, 88 Golf GL, 97 Passat TDI, 07 Jetta 2.5, 02 Beetle 2.0, 08 Jetta 2.5 with Aisin Box.
RabbitGTI is offline   Reply With Quote
Old January 24th, 2017, 22:29   #1656
k1xv
k1xv's Avatar
When I was in high school, another guy had a Studebaker Lark (pity him). He would shut off the ignition, and the car would keep running. He would have to put it in gear, put his foot on the brake, and pop the clutch to get it to stop running.
I guess Studebaker was ahead of its time.
Old January 25th, 2017, 07:08   #1657
tikal
So have there been other 'blow ups' with these homogeneous-charge compression engine types?
Or maybe it has been 'covered up' and the public does not know.
Old January 25th, 2017, 08:22   #1658
GoFaster
Moderator at Large
There can't have been any, because no current production engine uses it.
The hardware is more-or-less the same as a DOHC gasoline engine with direct-injection and variable valve timing on both intake and exhaust.
Brian P.
formerly ... 2006 Jetta TDI 5-sp, Spice Red, Unitronics stage 1, 0.681 5th gear.
and before that ... 1996 Passat TDI, Silk Blue
Old January 25th, 2017, 09:15   #1659
bhtooefr
ToofTek Inventor
bhtooefr's Avatar
TDI(s): None
There actually are current-production HCCI engines, but not in cars, and most of them aren't even 4-stroke.
(Model airplane diesels use HCCI with a carburetor (if you can even call it that), and you vary compression with a contra-piston in the head, until the thing is running smoothly.)
Not exactly relevant to modern attempts at HCCI, though.
Old September 20th, 2017, 09:59   #1660
soot1
A few days ago, I paid a visit to my local Mazda dealer, and as I was checking out the latest CX-5, I opened the fuel flap. Inside, I found a cap of the fuel tank, and right next to it was another opening that was covered by a piece of plastic. The sales guy confirmed my suspicion that this was, in fact, an opening for the future urea tank. He told me the dealership doesn't have any indication from the HQ when the diesels might be coming, but everyone on the sales floor feels the extra hole is a good sign we are getting closer. Who knows? Maybe we are.
soot1 is offline   Reply With Quote
vw diesel into a mazda rx7 lews930 TDI Conversions 307 November 19th, 2013 18:20
Upcoming RX-7 to be the next Mazda Diesel? gpshumway Non VW Group Diesels 28 May 5th, 2010 09:52
WTB: Toyota, VW or Mazda Diesel PU Intech Non VW Group Diesels 0 May 19th, 2007 17:01
Mazda MPV diesel tango_28 Non VW Group Diesels 0 March 31st, 2002 22:19
Page generated in 0.15999 seconds with 10 queries
[Output: 102.57 Kb. compressed to 87.72 Kb. by saving 14.85 Kb. (14.48%)]
