Old May 14th, 2020, 13:28   #16
Kevinski4
Kevinski4's Avatar
The thing about racing oil is, it usually doesn't have anywhere near the detergents that normal oil has, because in a racing application it's typically getting changed very frequently. If you want the best, I'd run Redline. Or Kendall. That's from a person who's running a 3 generation old family oil distribution business with a large fleet to maintain as well. Not someone who reads spec sheets that the marketing rep provided. But any synthetic API spec oil will work fine if you keep temps under control.
ALL API spec oil is different than it was a couple years ago. It's now CK4. Which is different than CJ4. Doesn't matter who's oil it is, the spec is different, so the blend is different. It's for the better.
Kevinski4 is online now   Reply With Quote
Old May 15th, 2020, 04:28   #17
Mongler98
Race vs daily drive. Extreem HP or lawnmowers. There is only 1 difference.
Oil chance Interval.
Old May 15th, 2020, 06:18   #18
Kevinski4
Kevinski4's Avatar
Ummm. No.
Old May 15th, 2020, 06:36   #19
oilhammer's Avatar
Fuel Economy: fantastic
What about racing lawnmowers.... ?
www.cardocautomotive.com
Old May 15th, 2020, 16:53   #20
ApriliaNut
ApriliaNut's Avatar
Default Whoa!
Originally Posted by sloinker View Post
Here is the site to go to for oil questions:
https://www.bobistheoilguy.com/forum.../forum_summary
I would contact this place for oil if it was my car. Get what you are paying for:
https://www.hploil.com/motor-oil
I just spent over an hour on the HPL oil site and watched the embedded video from the MavTv program. The most important parts to me were the testimonials from the engine builders and racers.
I'm gonna try the 5w30 in my 06 Jetta BRM next time I do an OC. But not without a couple of emails to them with a couple of questions.
Man that stuff is E X P E N S I V E!!!
And, yes I have no life!!
Ex SpoolinJim 06 one owner Jetta TDI w/Malone Stage 2. Love the suspension change to TDI Cup. Getting double the mileage of the C70 I sold. Happy Happy. Photo is of my Yamaha halo bike, a 94 GTS 1000 w/James Parker designed RADD front end. Can you say STABLE??
ApriliaNut is offline   Reply With Quote
Old May 16th, 2020, 18:01   #21
JDSwan87
Black Swamp Thing
JDSwan87's Avatar
I'm listening...
Stella (Mine now): 2005 Shadow Blue Jetta Wagon TDI 09A
Mods: RC1. VCDS HEX-CAN USB (near Toledo, OH)
JDSwan87 is offline   Reply With Quote
Old May 17th, 2020, 17:50   #22
travis45
travis45's Avatar
Here you go. My cousin's racing lawnmower...
14 Sportwagen. 267hp last time at the Dyno.
travis45 is offline   Reply With Quote
Old May 18th, 2020, 07:02   #23
oilhammer's Avatar
They are a sight to see... a lot of fun to watch!
Old May 25th, 2020, 17:38   #24
[486]
TDI(s): 02 golf ALH
Originally Posted by travis45 View Post
IBW, when you say the top number, do you mean first or second? The 5 in 5w40 or the 40?
the first number is tested at 32f, the second at 212f
the numbers are more or less just relative, not relating to any easily quantifiable unit
so at 32 degrees f, 0w50 is thinner than 10w30
but at 212f, they've changed places
also, when converted into more rational viscosity units like centistrokes or whatever, even a 0wXX oil at 32f is still significantly thicker than an XXw50 oil at 212
so you've no need to worry about going too thin with the "cold" number
ETA: for my input, I've been running t6 0w40 in the compound turbo golf, 18k miles since the last drain, but it has burnt 2 gallons in that time so that's as good as changing it IMO. Spun a filter on 8k ago, gonna do the next at 10-12 after having cut open the last one to find it looking fresh and clean
Anyone have a high horsepower beetle? ss04vv TDI Power Enhancements 13 February 13th, 2012 12:43
Engine Oil Level - How High Is Too High? TheKid7 TDI 101 31 April 26th, 2011 10:09
FS High Quality Tranny oil cooler, Fuel Pump evangelos Private TDI Items for Sale/Wanted 2 February 26th, 2007 11:11
High Quality Motor Oil Prices Rise SkyPup Fuels & Lubricants 1 December 5th, 2000 13:15
A High Quality Conventional Oil at a Low, Low Cost Ric Woodruff Fuels & Lubricants 8 June 9th, 2000 11:02
Page generated in 0.17134 seconds with 13 queries
[Output: 97.97 Kb. compressed to 84.01 Kb. by saving 13.96 Kb. (14.25%)]
