jester69
- Joined
- Jul 17, 2004
- Location
- Missouri, estatos unidos
OK, so i have been having starting issues and even though my battery was newer it was from a chain store and I figured it didn't have enough amp hours. So I bought a new dealer battery less than an hour ago.
Long and short of it is I have a new dealer battery at 12.5 volts and with the key on but engine not started I have a check engine and battery light lit. as soon as you start the car they both go away. (alternator a ok 14.4 volts running)
there was an intermittent low voltage code but I cleared it and it hasn't returned. Now when I scan with VagCom i get no codes whatsoever.
So now I have a check engine and battery light I can't clear. It is monitoring a system that has been independently tested to be at the proper voltage.
Any ideas?
Any ideas?
