Hi !
I own a VW TDI car ( called Vento ) with a 4 cylinder MK5 engine.
Its been almost 10 years since I bought it new and absolutely love it.
However, few days back I had sudden engine problem while driving and noticed the glow plug and engine warning sign. So I stopped the car immediately and arranged for towing the car at the VW service station.
VW service station guys did usual computer diagnosis and did not find anything.
Next they checked few things and told me the wires were damaged.
They replaced damaged wires and took the vehicle for road test. After the test, They informed me that car is not picking up speed esp. 1st and 3 rd gear and concluded it was issue with EGR unit. They wanted me to replace EGR unit , which costs hefty amount.
I told them this was common issue after emission software update and that VW should cover it or offer heavy discount. After doing more research, I found that EGR unit could be disabled without affecting engine/performance. This seems to be good option for me, as it would not cost me much and there was no need to wait for new EGR to arrive which would take around 12 days.
So they agreed and disabled EGR unit , only to find that this was not an issue at all when they took road test ! The car still has same pickup issue even after disabling EGR.
Then they suspected its injector issue but after swapping other ones confirmed the injectors are fine. All this has taken a week.
Now they have come back stating its an issue with ECM (ECU) which costs a bomb ! The car can drive upto only 60 kph speed ( 40 mph ).
I suspect that service centre guys are just trying to make money.
( first EGR unit replacement suggested, next injector replacement,...)
My questions are as follows :
1) Wouldn't ECM / ECU problem show up when doing computerised scanning and diagnosis ? ( show some faulty codes )
2) How car I be sure its ECM /ECU problem ?
3) Are there any other checks that can be performed ?
( like example, I saw sometimes ECM hose has a leak which can cause problem,
ECM re-programming /reset can fix issue ,....)
Any help, guidance , advice greatly appreciated.
Thanks !
Thanks !
