OEM or any ol' battery?
brandonkraemer
Cincinnati, Ohio
2003 TDI 1.9L 5spd ALH VE mkIV Jetta Wagon
Not to start a whole thing about this.... but I seem to recall a few years back reading something about only using OEM batteries for the ALH engines. Couldn't find that conversation but before I updated my failing battery I wanted to check about that with the group.
cheers!
scooperhsd
Kansas City KS
NB, 2000, RED(5 Speed conversion) 2015 Golf SE
If you can still find it, an OEM type 91R battery from your VW dealer should still be the best. If you can't, then a Group 48 / new style H6 that is used in the newer TDI's should be acceptable.
02tdivw
Mn
02 Golf Tdi
I would not buy OEM battery from dealer , if you are in north. I hade 3 OEM battery in 3 years... no more. purchased Bosh from Pepboys. No more winter issue. paid $163 whit 5 years replacing warranty. no one can beat that, now they have a little different price and warranty...
https://www.pepboys.com/product/details/838838/01637?quantity=1
jmodge
Greenville, MI
2001 alh Jetta, RC2 w/.205's 5speed daily summer commuter and 2000 alh Jetta 5spd swap, 2" lift, hitch, stage 3 TDtuning w/.216's winter cruiser, 1996 Tacoma ALh
just make sure it is "direct fit", some of the others don't have a provision for the stock hold down clamp. Data sheets should have dimensions, weight, cca, and reserve info. I tend to lean toward a smaller, lighter battery with good reserve rather than the higher cca. Middle of the pack direct fit, I would term it.
STDOUBT
Portland, effing Oregon
dos jettas
A local shop here "Halsey Import Auto" has a retail side with various parts, and they sold me a Bosch S5 for my Jetta. New last Oct, so far perfect. $135-ish
xjfish
Minnesota
01 Golf
Interstate H6/48 seem to work well in these cars. Slightly less than OE with a decent "Nationwide" warranty.
brandonkraemer
Cincinnati, Ohio
And by "direct fit" is there a specific size that meets this criteria?
jokila
Houston, Texas
2003 Jetta GLS, Manual
I have nothing but success with the OEM battery from the dealer. The cost is totally competitive and works 5+ years for me.
brandonkraemer
Cincinnati, Ohio
Thanks for the input. I went with OEM from a dealer, it was competitively priced and they delivered it free of charge which was good, mine was dead.
Of course they delivered me the wrong one and now i have to pull it and install another one.... but that is dealerships for you. At least they caught their error.
BTW, I had an interstate in there from 2006! So it had a good run.
Rob Mayercik
NJ, U.S.A.
2002 Jetta GLS, Baltic Green/Beige
Got my last one from Advance Auto Parts (an H7 AGM type).
Fits like a glove, has all the proper specs.
jmodge
Greenville, MI
There are several sizes in that catagory, I believe 3 or 4 at Napa, differing in reserve and cca capacities. The inner plate material and outside dimensions change, higher cca batteries being larger and heavier. but direct fit will have a provision for the stock holdown clamp. If it is not direct fit you may end up having to improvise a holdown.
jmodge
Greenville, MI
The reason I reference napa is due to a shop discount, I payed around $105 for Legend Napa batteries, and they easily go 6 plus yrs for me.
Fixmy59bug
Las Vegas, NV
2015 Passat TDI SE
I WOULD buy an OEM battery just for the warranty.
The OEM battery lists at $147 which is already better than most batteries. But when you factor in the 5 years warranty (3 years FREE replacement, 2 years prorated), thats a pretty hard warranty to be at the price.
P2B
Toronto & Muskoka, Canada
2002 Jetta, 2003 Jetta, 2003 Jetta Wagon
Have you asked one to start an ALH below 0F?
I too used to swear by dealer batteries when they were made in Germany by Varta, but I won't buy the Mexico made Enertecs they sell these days due to cold weather fails.
Simon
Namakan
Minnetrista, MN
2002 Golf, 2011 JSW (gone), 2004 Jetta (gone)
I bought my ALH Golf in 2010 which had an interstate battery the original owner had replaced. It lasted 6 years for me in the Minnesota climate and I only changed it due to age, not trusting it for the next winter.
Having said that I bought a battery from the dealer and have had no issues in 3 plus years.
scooperhsd
Kansas City KS
Simon
I've asked one to start my 2000 NB at 8F (about 10-12 years ago), and I wouldn't be surprised if this winter I'm asking for a start below zero, with one nonfunctioning glowplug - as I'm moving to Kansas City at the end of August. Probably need to have the head pulled to get that glowplug out and redress the threads for a new one.
belome
Mid MI
2002 Jetta GLS TDI 5-speed
Yeah, but the OEM batteries aren't the same now as they were 8-10 years ago.
What was an excellent battery for years (Varta) has been replaced with a new battery (Enertec) that is incapable of starting an ALH below -10F.
I guess they work fine for those that don't live in cold temps.
scooperhsd
Kansas City KS
If you really want to press the point - when VW was testing the ALH's for the North American market, they took them to Alaska, Yukon and Northwest Territories - without frost heaters, oil heaters etc - and they started fine at -40 .
02tdivw
Mn
02 Golf Tdi
when your oem battery is dead, dealer charging you $74 for testing the dead battery...for me in 3 years 3 oem battery was dead in winter. no more for me, Bosh AGM work like we need in the tdi car, 2 winter so far so good.
belome
Mid MI
I started mine at -37F, I had a nearly new Enertec that wouldn't roll it over. I did however make sure to have my Jump and Carry all charged up in my warm hotel room. The engine made some pretty good noises for a few seconds but it fired up.
pdq import repair
idaho
09 Jetta
AGM batteries in a system not designed for them is NOT an upgrade, in my opinion. Cars that do come with them as factory equipment don't seem to have as long of a life as they should.
I can buy both Bosch and Varta batteries from my suppliers, but when digging a little deeper into the MSDS on them you find Bosch batteries are made by Jonson controls (Interstate), and Varta is made by East Penn (my personal favorite for many years now).
Nobody ships batteries in from Germany anymore due to weight and EPA regs. I checked years ago and found VW factory batteries deep down were East Penn at that time. That was also part of my reason for trying them as a supplier in the first place.
Johnson controls makes a pretty good battery that many places like Costco sell, and I have tried them as my supplier too. My only complaint is that we see many cars come in with three year old batteries that have lots of corrosion due to acid leakage around the posts. That is why I quit selling them. East Penn lasts as well and the battery looks as clean at five years as the day you put it in, as do the factory batteries.
The problem with buying a random battery to try is that it really takes a five year cycle to prove that it is up to the task and wont eat the car away.
P2B
One of the OE batteries that came with my ALHs lasted 11 years, the other 12 years, and never failed to start the car in winter. The dealer batteries that replaced them both failed to start at least once during their first winter. I switched to AGM - have only had them one winter but no fails yet.
Simon
phaser
Oregon
2004 Jetta PD - 490k
AGM batteries in a system not designed for them is NOT an upgrade,....
Agreed.
Post 92 from this thread: http://forums.tdiclub.com/showthread.php?t=391746
That nice looking Bosch battery is an AGM, and from my reading, AGM batteries require a different charge rate then flooded batteries.
Some interesting reading here: http://forums.tdiclub.com/showthread.php?p=4718475
and here, post #5: https://forums.tdiclub.com/showthread.php?t=420022
and here:
"As with all gelled and sealed units, AGM batteries are sensitive to overcharging. A charge to 2.40V/cell (and higher) is fine; however, the float charge should be reduced to between 2.25 and 2.30V/cell (summer temperatures may require lower voltages).
Automotive charging systems for flooded lead acid often have a fixed float voltage setting of 14.40V (2.40V/cell); a direct replacement with a sealed unit could overcharge the battery on a long drive."
http://batteryuniversity.com/learn/article/absorbent_glass_mat_agm
OlyTDI
Olympia, WA
'04 Golf
My Golf is 14 years old and on its second battery. I used the dealer-sourced OEM. It was the least expensive as well.
rrgrassi
Royse City, TX
'06 Jetta TDI 5 speed
I still use Interstate. Auto Zoo used to be good, and Oh Really used to sell Interstate. Costco does sell Interstate.
