eurojulien
Vendor , w/Business number
I figured that posting this info would help some of you with this kind of kit.
I bought: Ebay Kit (but ordered black couplings with it (free) to stay away from the ricer look) and a map sensor bung
Total cost, right @ $200
I tried to keep the pipe work as simple and as short as possible..
My routing
Install intercooler temporarily with zip ties to crash bar, in/out side up.
1: Take a 90deg bend pipe and trim ~1".
2. Connect 90 degree bend pipe to the pancake pipe (trimmed side goes to intercooler)
3. Trim 180deg bend pipe ~1.3"
4. Install 180 deg bend pipe with cut side facing intercooler. The correct orientation is to have the pipe touching the condensor fitting next to the radiator, a slight modification (ie hammer) will give you enough room for them not to touch.. I also added a rubber pad in case they do)
5. Connect 45 deg bend pipe to 180 degree bend pipe. Correct orientation is for the pipe to be under driver's side fan and in between oil filter & pass side fan. (you will need to move some wires and maybe slighly re-route the coolant pipe coming off the thermostat)
6. Connect 90 degree bend pipe to 45 degree bend pipe.
7. Fabricate some sort of adapter from 2.5" to the factory intake elbow.
MAP Sensor:
A quick fix for the map sensor involves some RTV and zip ties. Works well to 24 PSI. Hasn't leaked in roughly 1 month, probably going to end up welding it to not catch too much flack
Mounting:
Once you are happy with the piping, attach intercooler with hardware, remove piping and spray hair spray on all the connections (trust me on this it helps you from blowing the pipes off down the road) I tightened the clamps as much as they would go with my 1/4" drive ratchet.
It'll take a good bit of trimming to get your bumper fitting nicely.. but it's possible.
Lip modification:
Now you are left with a dilemma regarding your front end.. either you
1. cut your crash bar and swing lower part of your intercooler up (keeping the hoses/connections where they are) Like this
2. hack your factory lip. Like this
3. Install GLI lip
I choose option 3 for looks & safety:
With intake pipes painted black and grill-inserts back on.
Results:
I have yet to see anything north of 105F intake air temps with my current state of tune driving spiritedly. A vast improvement over stock.
Oh and.. make yourself a free 2.5" turbo intake with left over couplings and piping!
My routing
MAP Sensor:
Mounting:
Lip modification:
3. Install GLI lip
Results:
