diesel4ever
Eurojet is installed on '00 Golf. I had to do some 'custom' work to connect the pipes to my 'stocked' VNT17, but everything else is OK.
The big problem is installing the front bumper cover on. There is a lot of cutting of 'extra' stock plastic involved. I hoped to retain the 'stock' look, but it looks like it will be impossible. Does anyone know if there are some other (aftermarket) bumper covers (i.e. Rieger) that would fit fine over this FMIC?
By the way, I checked the compression ratio on my engine and it's still right at the top of factory spec (31PSI) for all four cylinders. This was a very pleasant surprise considering there is 416,000km (258,000miles) on it. Is there a special coating on cylinder walls?
