Old March 13th, 2018, 08:56   #1
dweisel
dweisel's Avatar
Fuel Economy: 09 MB R320 Bluetec and too many ALH Beetles!
Default No headlights, no wipers and no turns
On my 02 Beetle daily driver, I have no headlights other than flash to pass. No wipers at all. No turn signals other than the hazards work fine.
I replaced the stalk with another one I had. Same results. NOTHING WORKS.
I'm stumped???
LUBRICITY,LUBRICITY,LUBRICITY!
dweisel isn't diesel anymore!
dweisel is offline   Reply With Quote
Old March 13th, 2018, 08:58   #2
aja8888
aja8888's Avatar
TDI(s): Out of TDI's
Fuel Economy: About as good as it gets!
Do a VCDS scan for starters? Or did it not show anything?
Originally Posted by Big Mike View Post
........"Everybody has a plan until they get punched in the face." -- philosopher Mike Tyson.
aja8888 is offline   Reply With Quote
Old March 13th, 2018, 09:37   #3
dweisel
dweisel's Avatar
No, I skipped that and dug right into it. Would of bet money on it that it was the stalk. I'll get it all back together and hook up to VCDS. TOO COLD right now to work on it outside.
Thanks Tony for reminding me. STEP ONE: Check with VCDS!
Old March 13th, 2018, 12:51   #4
phaser
Fuel Economy: 49 MPG B-20
Could this be a load reduction relay issue?
2004 Jetta BEW 5M - 470k - 49 mpg / Fuel B-20 / Fuel Filter - Cat IR-0750 /
Oil Filter - Hengst / Oil - Schaeffer Supreme 9000 5W-40 /
Bypass Filter EaBP100 /
Air Filter - EaA208
/ Transmission Oil - VW G50
phaser is offline   Reply With Quote
Old March 13th, 2018, 13:58   #5
dweisel
dweisel's Avatar
I have no idea. Where would that relay be located?
Old March 13th, 2018, 14:49   #6
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
Google "load reduction relay 2003 tdi", check the images
Old March 13th, 2018, 14:55   #7
phaser
It will be where all the other relays are located. Someone here can chime in where and relay number. Check Bently if you have one.
Post #6 - http://forums.tdiclub.com/showthread.php?t=356359
Originally Posted by AndyBees View Post
The load reduction Relay is totally separate. It de-activates all non-essential accessories when the Key is in the Start Postion!.............lights, radio, AC, heater fan, wipers, etc., are some examples that are de-activated during the Start Postion of the Key! That act gives the starter all the power available for "starting" purposes.
Air Filter - EaA208
Old March 13th, 2018, 17:45   #8
dweisel
dweisel's Avatar
Thanks for the input. Appreciate it.
dweisel
Releasing E-brake turns on wipers? Kingkong0193 VW MKIV-A4 TDIs (VE and PD) 6 June 26th, 2018 08:52
No headlights, turns or wipers???? dweisel Private TDI Items for Sale/Wanted 0 March 13th, 2018 08:33
Headlights, blower, wipers all go out. B4V. GTSLOW VW MKIII-A3/B4 TDIs 3 March 16th, 2014 13:31
Headlights,wipers out; fuses seem to be fine ablair12 VW MKIII-A3/B4 TDIs 6 July 29th, 2008 10:17
wipers/fan/headlights die mcquinn VW MKIII-A3/B4 TDIs 4 April 15th, 2003 03:52
Page generated in 0.14036 seconds with 12 queries
[Output: 91.05 Kb. compressed to 78.50 Kb. by saving 12.55 Kb. (13.78%)]
