Has anyone tried removing the oil for a change out by using one of those oil pumps for removing oil through the dipstick?
It sure is a hassle raising the car to put it up on jackstands just to get at all of the torx screws so you can then remove the drain plug. I notice in the Bently manual that they mention that VW uses a tool to remove the oil by some other means?
