Hi folks,
I have a 2010 Jetta DSG that is making a noise only while in park and when the engine is cold. Once the engine is up to temp, the noise disappears from what I can tell. From the reading I’ve done, I’m leaning toward what sounds like it could be a failing DMF. I’ve attached a video where I tried to record the noise and if you listen closely, you can hear the noise I’m referring to. Appreciate any insight. Thanks in advance!
https://youtu.be/CQie9WqkHUM
