NurseGuy1987
Hi guys. Here I am again with what is probably a simple issue. My AC has bwwn cooling "okay" since I purchased my car. This evening, I turned it on and it didn't cool. I hooked up a bottle of AC pro and tried "charging it" until it was in the green zone (on the ac pro bottle). Once it got into the green zone it still wouldn't cool. I was not able to check fans or the compressor clutch as I simply don't know enough about it. The fan inside blows strong, the AC light comes on when I push the button, as well as the recirculate button. It was working fine yesterday. What gives?!? Should I be concerned about overheating, as I was told that the thermostat has something to do with heating/cooling? What are some things to look for (and how)? Thanks in advance. Also, the doors are all working properly between floor, defrost, vents, etc. Also note, that it has been blowing out pieces of black/gray foam type material since I purchased it.
2003 MK4 TDI Beetle
100,290 miles.
2003 MK4 TDI Beetle
100,290 miles.
