fouillard13
reverse has the lowest ratio in the trans, so engine compression has the greatest advantage over driveline rotation... if your parallel parking by a curb turn your wheels full lock so it carves an imaginary arc INTO the curb
even when rolling backwards? I figured that reverse is a lot faster than 1st max speed that it would have a higher ratio and less strength.
