MAX,
Did you buy one of the turbos from gottuned.com?
https://gottuned.com/product/billet-wheel-gtb2060vklr-ball-bearing-upgraded-turbo-vacuum-converted-and-welded-onto-stock-1-9-2-0tdi/
I must confess to lusting after their GTB1756VK. I assume, and 'scuse
my ignorance, is that the water is for cooling the ball bearing shaft.
When I deleted my EGR, I got a SS nipple and tied those hoses together. I got the same advice as from flee, go metal for any of those
heater hose connectors/fittings.
Keep us informed as to progress!
My Jetta got GTD1756VRK and man I could not be more satisfied having that turbo in it,, I wish I could've had it 10 years ago when all of us with PDs and ALHs were going crazy with 17/22, what difference with this turbo,, could not be any happier,,, and Yes all of my projects will now be with GOTTUNNED in Poland, damn great guys to deal with,,,
going with the topic now and answering your question,, I am in the process of upgrading my GTB2260VK from my racer Golf and making it a GTB2260VK with ball bearing basically we need to change the CHRA from VK to VKLR , turbo still be GTB2260VK but with ball bearing, I am probably be the guinea pig with this project, it should be fun I will dyno and see results in my ALH, I imagine it will spool quicker than journal bearing vk turbo,, I will do WPC treatment on shaft, bearing, maybe wheels and any internal that may need to be treated, so I can get best result with less fatigue and less friction giving me stronger metal surface and longer longevity on internal parts I understand there are some members that will always be skeptical no matter what, but hey let me try it and see,, I may even get a quicker spool by doing such treatment on it too who knows??? hey I am the guinea pig on this on this project anyway,,,,, project is under way..
