Tab3538@hotmail.com
I recently had a water pump seize on my daughter’s 2000 VW Beetle TDI. The exhaust valves bent so I got the head inspected for cracks and rebuilt. Using careful instructions from this forum, I timed the cam shaft, locked it and did the same for the crank. Long story short, I have it all together now but it won’t start! I did follow the timing belt PDF to a tee (profound thanks to the author). I turned over the engine manually twice as prescribed and everything stayed aligned.
My only hypothesis is that maybe the injector pump got out of time or glow plugs are not working as the the harness looks like hell.
Sincere thanks for any help the forum can offer
Tony
Tony
