Jettasteve
Help in need of some input/help/direction. I have read numerous posts of glow plug issues and this is where I'm at.
Having trouble tracking down the cause of the glow plug codes and check engine light on my '04 Jetta Tdi with the BEW engine, 5 speed manual. A little history: Started to rebuild the old girl about 2 yrs ago as I miss driving her. New fenders, rockers, timing belt, filters, fluids and complete body restoration. It now runs, sounds and looks all original. It was having an small glow plug issue pre-restore, at that time for cyl. 2 glow plug but I never pursued at the time. Now restoration is complete and it is giving the check engine and all 4 glow plug codes. Thought it was strange to have all 4 GP codes so decided to check GP's with ohm meter and they all checked well within spec at .7 . When pulling the GP harness off most of the boots broke so purchased a new harness and spliced the wire under the cover near the original connector, so the splice would be more out of the elements. Cleaned the grounds from the engine to body while there. Fired up the VCDS and still had all 4 GP codes. Cleared all the codes and re-ran the VCDS. Still all 4 codes. After researching the issue seems the GP relay was next in line as the problem. Installed another GP relay and VCDS still giving all 4 GP codes. Stumped. Ohmed the female connector pins to each GP boot in the harness, all OK. Checked each boot for power after unplugging the coolant, nothing, no power to any of the boots. Checked all connections at the battery and all fuses on top of the battery, all is good at 12.8 v. Disconnected the harness plug again and tested the pins for supplying power to the GP from the GP relay, no voltage there. Checked for power at the GP relay, the big blade near the bottom that should have constant power and had 12.8 v at that point. Should add the glow plug light on dash lights up and goes out as it should.
Thoughts running through my brain, is ECU giving signal to GP relay? How could that be checked? What are the chances that 4 wires from GP relay to connector under the cover behind the air box being bad at the same time? ( Don't want to strip all the wire covering off the harnesses until everything else has been checked out). Is there a bad ground I'm missing somewhere? I did clean up the ground near the ECU. The GP relay has 9 pins, top row is power to GP's, center 2 pins of middle row?, bottom row left pin? center blade pin 12v constant power, right pin?
Any Ideas?
Any Ideas?
