Hey all, I have an 04 BEW with about 300k miles on it. I'm going to be doing a bit of work on it tomorrow and had a couple of questions.
First, the tandem pump is leaking diesel and I'm going to replace it. I've read a few threads on it, and was wondering if it's as straight forward as it seems? I saw that I need to be careful with the vacuum line, and then turn the cam horizontal for the install. Anything else I'm missing? Do i need to take the valve cover off? A few months ago it was leaking a good amount of oil, and I RTV'd it down. Probably not the best solution, but I had to do it. I'm hoping not to have to deal with that mess.
Secondly, I'm replacing the turbo with a VNT17 as a semi-extreme preventative maintenance. My car still has the KP39 on it and as far as I know, it's the original one. The PO gave me a bunch of receipts from when it was new, and there's nothing about the turbo in there. I drive about 350 miles one way to work, and half the time there's no cell service, so I figured I'd swap that while I'm on my off season. There's a few things I wanted to clarify:
- I saw some posts saying that it's possible to remove the turbo from the top and just wanted to verify it is? I have the EGR deleted already, so I'm not worried about that. I watched a video where the guy pulled it from the bottom, and since I don't have a lift, I'd rather not have to lay on my back to do it.
- On the car is a Stage 1.5 Malone tune, would I have to go back to my tuner to get things adjusted?
- Is this as straight forward as it seems? I replaced the cam and TB last year, and i feel comfortable doing this. Just wanted to make sure there won't be any surprises I haven't seen in the other threads. I do have the braided steel feed line, so I'm not worried about wrecking the stock one.
- And lastly, do i need to do anything to prep the new turbo for startup? I got some of that "new turbo lube" from ID parts and was just going to use that.
Sorry about the long post, I just want to make sure I have all my ducks in a row before I start this.
