Old July 19th, 2019, 00:41   #1
RustySax1949
Fuel Economy: Yup - it's a TDI!
Default Diesel Oil, or "Here we go again!"
I'll probably get heavily flamed for this story, but here goes anyway:
Since I bought my 2003 Jetta TDI, I've used the correct VW-spec oil in the ALH engine with each oil service. But 5,000 miles ago, I found myself in a dilemma: Engine was due for an oil change, we were campground hosting miles from the back forty with no approved oil anywhere to be found, and no time to spend searching for some. Plus extremely poor internet service, let alone getting it delivered.
I remedied the situation by using Mobil Delvac 1240 that I carry on the RV to feed it's engine - a 450 hp Detroit Diesel 8V92T. Yup, 12 liters and 1400+ ft.lbs of torque back there, just a wee bit more than the TDI. It's a straight 40wt with a 0.80% sulfated ash content, and an API (now retired) CF-2 rating. (You can buy the same oil at a Detroit Diesel dealer's parts department under their "Power Guard 40" label.) This oil is formulated for the HD two-stroke engine, one which the mains and connecting rod bearings never get a "rest" between power strokes, unlike a Cummins, Cat, a current generation Detroit, or even our beloved TDIs get. And, yes - I did install a new oil filter at the same time.
Since I'm coming due for another oil change at 235,000 miles, I thought I'd share some things I've noticed while running the "wrong oil" for my engine:
1) It doesn't blow blue smoke out the exhaust when first started. Factory-spec oil killed lots of mosquitos until the engine warmed up.
2) It still starts easily (I live in temperate climates year-round.)
3) It has not used ANY oil at all over 4900 miles. With the VW-spec oil it nearly always was down a quart at oil change time.
4) The engine seems to be quieter, not as much clatter.
So that's my story. I doubt that I've done irreparable damage, but thought others might be interested in what happens in a light-duty diesel when it's fed heavy-duty diesel oil.
Let the flames begin!
RustySax1949 is offline   Reply With Quote
Old July 19th, 2019, 01:07   #2
CleverUserName
I would love to see an oil analysis to show the wear patterns on this oil. You may be the only person to ever try this in a VW diesel.
Im a fan of using “real” Diesel engine oils in our cars. A quality synthetic CJ-4 or CK-4 will perform better, hold soot in suspension and prevent wear better than any 505 oil can. With that said, SAE 40 is really too thick for an ALH. DD 2 strokes shear oil so multigrades aren’t recommended in these applications. It’s also CF spec which is ancient.
Thicker oils tend to quiet engines. No surprise there.
Thicker oils also reduce valve stem leakage, so less smoke at startup and less consumption.
Monogrades generally are less volatile, so less consumption as well.
You may get the same effect if you try an SAE 30, there are some synthetic monogrades, which would be more suitable for the turbocharged ALH.
CleverUserName is offline   Reply With Quote
Old July 19th, 2019, 07:32   #3
Jetta_Pilot
Jetta_Pilot's Avatar
Location: West Hill, Ont. Mexico mid October 2019 to end of April 2020
Just for whatever it's worth, many years ago a member in Ontario with a then MK IV had the oil changed to correct VW specs, at 10,000m had the oil analyzed at a lab. Result oil was still 100%. Had it analyzed at 20,000m again at the lab and result was the oil was still 100%. Then at 30,000m had it tested again and the oil was still good.
So why some people are so anal if they go a bit past the "due" date is beyond me?
Nothing bad will happen if you extend the oil change by a few thousand m/km!!!
All LED interior bulbs. Several VCDS mods. Darker window tint. EVO skid-plate. Malone Stage 2, Malone DSG tune. Winpower Projector headlights. Angel eyes. LED DRL's. 24mm H&R rear sway bar. Phase 1 & Phase 2 done.
Old July 19th, 2019, 07:54   #4
turbobrick240
turbobrick240's Avatar
That oil should work fine until you encounter cool weather. I'm in agreement with JettaPilot, the correct spec oil doesn't just expire at exactly 10k. I've extended the oci to as much as 15k while traveling.
turbobrick240 is online now   Reply With Quote
Old July 19th, 2019, 13:28   #5
RustySax1949
Hmmm. . .
Maybe I'll just change the filter and pull an oil sample, something I do regularly for the big DD. Will also be interesting to compare samples between the four-stroke VW and the two-stroke DD. . .
Turbo - I live in the RV full-time and "snowbird," staying in 60-80 degree weather year-round, so I don't think cooler weather will be an issue with the Jetta.
FWIW. . .
Old July 19th, 2019, 15:13   #6
scooperhsd
Honestly, you should have used a CF-4 or newer spec oil. But as long as it didn't blow up....
2000 Red NB TDI, 370,000+ miles
Now 5 speed manual and onto 500,000 miles + !
2015 Golf TDI SE DSG
scooperhsd is online now   Reply With Quote
Old July 24th, 2019, 06:48   #7
belome
Fuel Economy: 47'ish
The best part, it looks like he is using 5k OCI's.
The only thing I can pass is a fuel stop, but I'm OK with that.
My claim to fame - I was banned from VWVortex!
belome is offline   Reply With Quote
Old July 24th, 2019, 07:45   #8
turbobrick240
That's not how I read it. In any case, hopefully he does send in a sample for analysis, and reports back with the findings.
Old August 3rd, 2019, 23:28   #9
tdiman
tdiman's Avatar
Mine will be at 20,000 in 6,000 miles will be testing and then Designing to continue or change
tdiman is offline   Reply With Quote
Old August 4th, 2019, 03:17   #10
When TDIs were launched in the mid-90s VW didn't spec synthetic oil. However, they found the non-synthetic was developing coke on the top piston ring (allegedly because of its proximity to the combustion event) "freezing" the ring and causing excessive oil consumption. They switched the oil requirement to synthetic and the 505.00 spec.
So one fill with single weight non-synthetic may have been OK, but continued use may be risky.
2002 Jetta wagon, 390K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 286K; '99.5 Golf, 260K; 2011 335d, 60K; 2015 Golf Sportwagen, 13K. Principal, http://www.idparts.com
Old August 4th, 2019, 05:09   #11
johnsTDI
Location: Canada,ont North America were Neighbours to usa
Fuel Economy: oh gosh alot better than burning Gasoline.?
You should Only use the proper spec and Viscosity Oil it calls for on Your engine I Only use dealer spec 5w30 Castrol Professional Oil & filter in my 2012 TDI $50.00 for Oil & another $17.30 for Oil filter at Local VW. i could use mobile 1 esp at $15.00 a liter but the dealers is cheaper and its proper oil & filter i change Oil & filter myself at 5,000 km's because its equiped with a turbo and i want to extend its life. but thats me many will argue that there extending there oil changes 15-20,000 just keep in mind. the Oil filter is in bypass mode at that mileage so its no longer filtering oil
but letting dirty oil back into Your engine. and if its a equiped with a turbo your jeperdizing its life span by wearing it out earlyier than normal. Oil is still cheap to buy vs buying an engine or turbo unit. many examples online of people pushing there oil changes well beyond the life of the oil change rec. with a disasterous & expensive $$ outcome.
johnsTDI is offline   Reply With Quote
Old August 4th, 2019, 05:46   #12
turbobrick240
5k km oil change intervals? Somebody has been reading the Jiffy lube brochures.
Old August 4th, 2019, 11:09   #13
CleverUserName
Changing the oil every 3,000 miles is silly and a waste of resource$. If youíre doing it to reassure yourself then Iíve got some bad news for you...
I wish I would have used a different oil on my Ď09 buyback Jetta. Those 2.0 TDIs shed lots of iron because VW used main injection to supply fuel for Regeneration of the DPF and it washes the oil off of the cylinders. I never tried a 5w40,10w40 or 15w40 Real Diesel oil but Iím sure it would have resisted the cylinder washing better than the 5w30 507 oil they tell you to use. VW finally figured it out with the 2015s.
If you donít believe me install a magnetic drain plug on your oil pan. Itíll blow your mind how much metal is on there. Itís all grey cast iron from the cylinder walls.
Old August 4th, 2019, 13:19   #14
johnsTDI
Old August 4th, 2019, 13:39   #15
johnsTDI
im not fond of Getting Oil Analyzed because it wont tell You the true condition of piston bearings. if Your thinking of pushing Oil&filter to 20-30,000 usa mile intervals thats asking for trouble. because theres no Oil filter on the market that will keep filtering past around the 7,500 usa miles it will go into bypass mode and not filter anything in bypass mode its letting all dirty diluted contaminated Oil thru the Filter into Your engine is that worth it? really.? Your better off spending the lousy $75.00 on proper spec oil & filter than to sit back and risk & watch the engine wear down to crap. fresh oil Preserves engines not contaminated dirty extended oil changes.
Its April..anyone find "new" Mobil 1 - Turbo Diesel Truck oil... BurpleTDI Fuels & Lubricants 260 June 3rd, 2007 06:12
VW dealer said diesel additives "snake oil"? zonaman1 VW MKV-A5 Golf/Jettas 9 September 15th, 2006 21:09
"lean" & "rich" diesel mix temps. skippytdi TDI 101 12 June 22nd, 2006 06:59
"Mileage" vs. "MPG" vs. "Mile range" vs. "Miles per tank" boyelectric TDI Fuel Economy 33 August 19th, 2002 06:06
5w-30 diesel oil named Lubricants World "Product of the Year" TooSlick Fuels & Lubricants 27 July 25th, 2002 00:46
Page generated in 0.20042 seconds with 13 queries
[Output: 131.57 Kb. compressed to 110.94 Kb. by saving 20.63 Kb. (15.68%)]
