volkstechnj
I am having a problem swaping an ECU in a 11/95 Passat Wagen
The Orignal ECU will not let the car go over 60mph
The replacement dealer ecu will not let me change soft coding and has 2 codes along with a CEL and flashing Glow Plug Light. However the car runs well and can reach 80MPH.
Any one have any ideas?
Below is an autotext file
>>> 11-95 passat tdi wagen 1Z657 995 vin wvwhg83a3texxxxxx
>>> Replacement ECU New From Dealer
>>> Thursday,05,April,2007,14:57:31
>>> VAG-COM Version: Release 607.3-UD
>>> Chassis Type: 35 - VW Passat B4
>>> Scan: 01 02 03 08 15 25 41
>>> Address 01: Engine
>>> Part No: 028 906 021 GQ
>>> Component: 1,9l R4 EDC G00SG 1420
>>> Coding: 00002
>>> Shop #: WSC 00000
>>> 2 Faults Found:
>>> 01044 - Control Module Incorrectly Coded
>>> 35-00 - -
>>> 00309 - Washer Solution Metering Pump (V135)
>>> 31-00 - Open or Short to Ground
>>> Readiness: N/A
>>> Address 15: Airbags
>>> Part No: 6N0 909 603 G
>>> Component: AIRBAG VW2 V00
>>> Coding: 00071
>>> Shop #: WSC 05311
>>> No fault code found.
>>> End
>>> Original ECU
>>> Thursday,05,April,2007,15:01:19
>>> Address 01: Engine
>>> Part No: 028 906 021 BK
>>> Component: 1,9l R4 EDC SG D5O
>>> Coding: 00000
>>> Shop #: WSC 00000
>>> 1 Fault Found:
>>> 01242 - Output Stages in Control Module
>>> 27-00 - Implausible Signal
>>> Readiness: N/A
>>> Address 15: Airbags
>>> Coding: 00071
>>> Shop #: WSC 05311
>>> End
>>> Address 01: Engine
>>> Coding: 00002
>>> Shop #: WSC 00000
>>> 2 Faults Found:
>>> 35-00 - -
>>> Readiness: N/A
>>> Address 15: Airbags
>>> Coding: 00071
>>> Shop #: WSC 05311
>>> End
>>> Original ECU
>>> Address 01: Engine
>>> Coding: 00000
>>> Shop #: WSC 00000
>>> 1 Fault Found:
>>> Readiness: N/A
>>> Address 15: Airbags
>>> Coding: 00071
>>> Shop #: WSC 05311
>>> End
