Blend door repaired: 2 hrs labor $8 part vs $1,500+
It is truly amazing how this and other forums can save the DIY VW owner thousands. I, too, had my AC go to full hot during a brutal August afternoon in Gerogia. What was going on?
The local import shop informed me that the "blendor" as they wrote on the estimate was "broken". They told me the entire dash had to be removed and the Air Distrubution Housing $450, Heater Core $150, Evaporator $300 would need to be replaced, AC charged and $600 labor. Total cost around $2,000. I thought i didn't have any other options.
I found this post at VW Vortex that helped me fix this problem in addition to the posts here:
http://forums.vwvortex.com/showthread.php?4445527-DIY-Heater-Air-Conditiong-Fix-(blend-door-issue)
The part you need is called a "Pin" but it's really a plastic bushing with two cheap plastic tabs--one of mine broke and it fell out of the housing.
The part number you need to buy is 1H0 819 136
World Impex sells it for $7.98 i believe.
The most challenging part was working in a very confined area. What i can't get over is either the laziness or plain ignorance of repair shops that won't make the effort to fix this with a $8 part. Screw them. Good luck to all of you fixing this problem. My dowel trick that is listed below was my key to getting the metal tab on the blend door alligned--it's very hard to get centered and it does need to be centered within .040" or so.
Here is how i did it:
1. To make the job easier, I removed the passenger seat. Take care wtih removing the airbag connections and
be warned that removing the seat will trip the airbag light on the dash. Make sure you have a vag-com to reset when you are done.
2. Using a small, circular mirror that's adjustable (a must for this job) i noticed that the metal tab at the bottom of the blend door was not centered. I also needed to figure a way to know the orientation of that tab for lining up the replacement bushing "pin". So, i bought a 3/8" dowell at Wal-Mart, cut it to about 1.5" and then cut a slot in the top about 1/4" deep and beveled both sides. The kerf of the jigsaw blade was about .020" bigger than the metal door tab and worked perfectly. Draw a black line from the slot down each side so you have a reference as to the position of the blend door. Insert the dowel in the hole and orient the metal tab. I made a mark on the housing wtih a white marker for reference. Make sure the door is centered and then gently slide the bushing in place.
3. For my Jetta i used a 6mm combination wrench to undo the screw at the bottom. Didn't have enough room for anything else.
I also had the carpet and soundproofing out of my car on the passenger's side due to a leaky sunroof drain--not sure if that was critical to performing this job. It might be a bit harder wtih the carpet.
The key is patience to line up the blend door and also make sure you are comfortable while conorted in the passenger foot well. Good luck!!
