GT1749VA Melted VNT ?
ownyzo
Bulgaria
mk4
My turbo just broke, the wheel on the cold side got busted... But this is how the hot side looks >
It seems like it started melting. The vnt was stuck hard, what can cause this.
remaped, 0.240, 10mm pump, gt1749va
pushing about 160bhp, 390nm.
ownyzo
Bulgaria
mk4
No i dont have egt guage. Stock IC and exhaust, wich im told should be good to about 180 bhp. WOT nothing more than 2-3 min. Is it to much?
crazyrunner33
NC
'10 Golf(bought back)
I believe that generation turbo can only handle 1650 sustained. You're pushing it a bit hard for that turbo, it's a bit small for that kind of power. If you're pushing that much power continuously, it'd be worth it to step up to a GTB or newer generation turbo that's designed to handle a DPF. Those turbos are designed to sustain over 1900 degrees.
Curious Chris
Pineview GA
Jetta Wagon 2003 RIP Rockford IL
Yes it is good to 180bhp with a large fmic and and a EGT gauge. My 2002 was 150 bhp and if I floored it on a hill in 5th the EGT would climb upwards to 1600 on my gauge, so I would downshift reducing load and the EGT would drop.
