VWYankee
I just installed my Autotech 28mm adjustable rear sway bar on Friday evening. I thought there was a huge change in handling by doing the suspension (shocks and springs). After that mod I was talking to a friend that had done shock and springs on one car, and just added a rear sway bar on a different car (with stock suspension). He thought the rear sway bar had a bigger effect on minimizing body roll.
All I can say is I believe his statement now, or at least that it's pretty close to accurate! I would say to those that don't want to lower their car and don't want the boat feeling to first put a rear sway bar on. It's less money and easier to install that shocks and springs. If you want the combination, your in for a real treat. Awesome combination. One of my goals after 'inheriting' the Jetta from my wife was to make it at least as fun as the Audi Coupe I just sold.
I've already well surpassed that with the minor things I've done! I would highly recommend adding a rear sway bar before doing shocks and springs (if not the same time), as you'll still have the same comfort with bumps but much less body roll.
Cheers!
Cheers!
