I have been fighting a electrical drain that has been killing my battery if it sits for 2 days or longer without running.
I have tried to find it with no results.
The amp draw with the doors locked and everything turned off was only .05 amps or 50 milliamps if I am correct.
Battery is oem and less than 1 month old.
I was getting something out of the hatch area and thought I would check to see if I had plugged the monsoon amp back in after my last series of testing and when I felt it, it was very warm. The car had been sitting for 2.5 to 3 hours.
I have an aftermarket kenwood head unit which powers the sony component front speakers but I still retain the monsoon amp for the rear speakers.
To achieve this I had to leave one of the front speakers negative wire connected to the monsoon harness as well as running it directly to the door speaker.
The monsoon amp is triggered by sensing voltage on this wire so I had to do that to get the amp to turn on with the head unit.
For some reason the monsoon amp was constantly recognizing a signal even though the radio and car were turned off, so it never turned off.
Since I have a custom box with 12" speakers and an amp in the hatch I already had a "remote tigger" wire conveiniently in the hatch.
I cut the hot wire (12v +) in the green plug going to the monsoon amp. (there are three hot wires there but about 10 inches back in the harness they become one larger wire). I used a 30 amp relay triggered by the aftermaret head units remote trigger wire and now the amp turns off with the stereo and remains turned off until the stereo turns back on.
I am planning on letting the car sit for 2 days now and I will post if it worked.
I am pretty sure that was the problem because of the amount of heat coming from th monsoon amp after it was not in use for over 2 hours and should have been cool.
