credditt
I'd like replace my instrument cluster in my Jetta TDI with an MK6 Golf TDI cluster to get the full MFI. Here's what I know so far (based on web research).
1. Despite the difference in physical appearance, the Golf cluster will fit in the dash opening and the mounting screws will mount up.
2. The connector plug is the same.
3. The pinout on the MK6 Jetta cluster and MK6 Golf cluster is different. While the Golf cluster will physically mount up and plug in, it won't function at all.
I believe that an adapter harness could be constructed to plug between the MK6 Jetta instrument cluster wire harness and the Golf instrument cluster that could "convert" the pinout.
Does anyone have, or know where I can find, the MK6 Jetta or Golf instrument cluster wiring diagrams?
(Cross posted in MK6 Golf and MK6 Jetta forums)
