It is a cover because it is a new turbo wich is modified by FIN-turbo.We all wish we could get our hands on one of these cars!
What is up with the electronic actuator? Is that a cover or a diff actuator?
It is not an automatic, just the OEM clutch wil handle this, an automatic wil handle this too.Nice result! What clutch do you use? Or automatic maybe?
1. If you hollow out the dpf, they will not be able to tell from looking on the outside. The tune can do dpf delete with everything in place untouched and only hollowed out on inside.1. I live in Denmark and our lows are very restrictive. I.e. if I remove the DPF and the 2nd year inspection unveil this, I will get a massive ticket - any idea how much power it will take out of the equation ?
I will in the process take out the PDF and "flush" in order to clean it as new - any concerns to this ?
2. My Audi is with manual gear model year 2007/2008 - will the gear be able to go above 600 nm ? (I hear some people say that this is the limit with the old manual gearboxes)
3. Today the car is already chipped and has 302 HP and 582 nm - will I need a remapping of the control box/chip after installing the new upgraded Turbo and larger Intercooler ?
Custom turbine & compressor wheels for vklr & vkI love this, but how much are these FIN turbos ??
Best solution, put DPF back når bilen den skal til syn, but do it about one week before going to inspection so the DPF can clean the sot of the mufler.!Hi Eddie and Jos!
Thanks for your nice answers on my 3 questions. I have today bought a Supersprint DPF replacement and tend to install it in the process.
I will fit the car for the 2. yearly inspection with the "old" PDF as it will be placed in the rear end (maybe hidden in the muffler) so that the emission when measuring is OK - and then take it of again (like a plug and play solution ;-).
So now I just need to send my Turbo to Darkside Development for an upgrade, install it all an get a remap and see how much more power I can get ;-)
Thanks gentlemen !
;-) T
