andrewjoseph
Greetings -
I read the FAQs and found a similar problem, but am not sure if this is the same thing. My wife came home last night and turned the car off. Then about 20 minutes later the fan started running and would not shut off.
I started the car again to see what would happen. The fan turned off when I shut the ignition off, then started back up in about 20 seconds. I looked up at some of the remedies and checked the 16 and 25 fuses. The 25 was blown so I replaced it. The problem has not changed at all after doing this.
My question is does this sound like a radiator fan switch in need of replacing or the auxiliary fan relay which from reading appears to be under the battery.
Lurking here for months searching for info, great site. Never had question I couldn't find by searching - thanks for any help!
