Hole sizes are not relevant to flow of any nozzle since this does not reflect the caviation effects that are caused by larger diameter holes and the turbulence created by the flow entry into the nozzle channels.
Also hole size is simply a function of the initial production process, there are several other steps performed that determine the ulimtiate flow characteristic of a nozzle. It's like comparing displacement of an engine and trying to determine what the HP per liter without knowing the actual HP... Size is a factor, but actual flow (of the nozzle) is the defacto data point that really matters.
As a further example, current production engines are getting 140Hp from a 2.0l engine using .117 holes, in the past the same engines were producing flows that supported only 90hp from .183 holes. The evolution of the nozzle has advanced that much in recent years.
Because of wide ranging variables all Flow data is measured on a nozzle flow bench using ISO 4113 calibration fluid. This measures peak volume delivery and cavitation effects. Nozzle flow is pushed to max delivery until flow drops as a result of cavitation, peak delivery volume, and slope of delivery relative to pressure (build and drop) is then recorded.
Nozzle evaluation cannot be done on the injector since there are variables introduced (pressure, flow, needle control etc) that cannot be standarized to provide a valid data point. All new Common Rail nozzles are set this way and that data is then emobossed on the injector which is loaded into the ECU. For fuel systme manufacturers, this allows a wider tolerance for manufacturing but a tighter control tolerance when installed on the injector body in respect to how the ECU controls that respective nozzle/body combination.
The reference flow nozzle is the DSLA 150P 706 Bosch PN# 0 433 175 150 (90hp 10mm pump configuration ALH TDI).
