stomachbuzz
System holds vacuum great. I tested it in multiple spots. Could not force a leak. I also waved around my propane torch cylinder. Nothin’.
I might replace the vacuum lines down the road, but I’m somewhat confident they aren’t the issue.
Actually, it’s kinda funny, vacuum lines are such a popular culprit to point fingers at, but I’ve probably wasted 10-15 hours of my life checking for vac leaks. Never had a single leaking vacuum hose in my entire life of car ownership. 8 years, 120k miles between 10-12 vehicles, the newest of which is currently my 2005 Tacoma.
If you want to give me a specific spot to look more closely, sure, but for now I’m tenpted to continue on the list of “low power” suspects
Editing after I remembered that I did not check the vacuum line going down to the turbo. Will do that later
