NB_TDi
Radio settings aren't removed from changing a battery. But the time and the trip-odometer are cleared.
This GIZMO is a life-saver! It saved me much trouble replacing a battery in a Camry with an alarm system. Add that to a list of automotive devices that go bonkers when the juice goes away.T_D_I_POWER said:
However he didjasonTDI said:You won't have an issue with the radio disconnecting the battery in an A4....
$9 here.fitzski said:Is there a core charge on batteries from Walmart, refundable if you bring your old one back?
If the store has an auto service department, they will install the new battery for free. Other stores sell batteries but do not have a service department, so their procedures would be different.fitzski said:Is there a core charge on batteries from Walmart, refundable if you bring your old one back?
I'm heading to upper NY tomorrow and am considering picking one of these up if the Walmart in Ogdensburg has any on the shelf - much cheaper than anything local. Wondering if I should plan on swapping it out in the parking lot.
And forward all the cash on Boxing dayNB_TDi said:....I should go battery hunting around Christmas time
Both made by JCI -- Duralast's are and at least some of the Everstart 94R's are -- but 765 CCA is better than 610 CCA.eb2143 said:Picked up mine last week...black case 3 year free replacement 910 CA...fixed my slow cranking...thanks Paramedick wouldn't have thought of Wal-Mart really.
PS: I can't recommend Autuzone Duralast gold, 94R only had 610 CCA and fell on its face in cold weather...from the beginning!
Yeah it's quite a big difference for a battery by the same company of the same size, huh?TornadoRed said:Both made by JCI -- Duralast's are and at least some of the Everstart 94R's are -- but 765 CCA is better than 610 CCA.
