52172
Whose running it? What kind of mpg’s are you getting? 50whp bump and 100tq! Will this pass Ca smog test?
Are you referring to a Malone stage 1 ? stage 2? with or without a DPF delete?Whose running it? What kind of mpg’s are you getting? 50whp bump and 100tq! Will this pass Ca smog test?
Yes we have phase 2 tunes out, deletes are a free option, they're not required.
CA smog for diesels is more than a opacity check. They are supposed to hook up to the ECU and verify integrity. If your tech is doing that then you'll want a flashzilla to be safe since you can simply flash it back and forth from tune to stock at will. That won't, however, save you from the dealership picking your tune up during a visit and flagging your VIN thereby voiding your extended warranty.
So even if I flashed back to factory tune before having car serviced the dealer would be able to tell I was running an aftermarket tune?
Yep, roughly double our ALHStill has 150 hp and gets 40’s mpg that good.
