So I have been trying to track down an issue where my clock and trip randomly reset. Majority of the time when they reset is when I shut off the car and remove the key. But now I am finding more issues popping up. I get the 3 beeps for the low oil pressure, but no lights and oil is fine, this happens about every trip in the car, usually in the first 5 mins. Then when the car auto locks the doors after you drive for a bit, mine is actually unlocking all the doors. I have checked fuses and they are all fine, but when I just touched #42 for the radio, it turned off my cluster. Also I noticed I have a 5amp fuse in #37 when my schematic calls for a 10. So far I have only replaced the fuse block on top of the battery and the alternator cable, because it was insulation was gone causing it to melt the box. And I have cleaned the grounds under the battery, which I had one rusted out that instantly broke. After I did that it reduced how often my cluster would reset, but now I am back to every time I remove the key. Any ideas?
