bmwM5power
- Joined
- May 3, 2007
- Location
- Rochester NY
- TDI
- 15 GSW TDI S 6MT 02 JETTA TDI GLS 5MT 15 GOLF TDI SE 6MT 15 GOLF TDI SEL DSG
getting very little to no heat on the 05 BEW Golf TDi, feels a lil warmer when flow directed to the windshield, but to feet or forward/face pretty much cold, also the air flow very weak even at 4 setting. Theres a coolant movement from the return line when looked in the expansion tank, so pump prolly works fine, the engine is reaching operating temp but the temp needle kind of stays on the lower side, not straight up. Blend door or thermostat?
