Parts Covered Under Extended Emissions Warranty
The Extended Emissions Warranty covers the entire emissions control
system, including (1) all components which are replaced as part of the
emissions modification, and (2) any component which can reasonably be
impacted by effects of the emissions modification.
The Extended Emissions Warranty shall cover the following parts or
systems:
The entire exhaust gas after treatment system, including the Diesel
Oxidation Catalytic converter (DOC), the Selective Catalytic
Reduction (SCR) Catalyst, the Diesel Particulate Filter (DPF), the
dosing injector and other Diesel Exhaust Fluid (DEF) system
components, any exhaust flap, and all sensors and actuators;
The entire fuel system, including fuel pumps, high pressure common
rail, fuel injectors, and all sensors and actuators;
9
The Exhaust Gas Recirculation (EGR) system, including EGR valve, EGR
bypass valve, EGR cooler, EGR filter, all related hoses and pipes, and all
The turbocharger system including all related hoses and pipes, all
The Engine Control Unit (ECU) and the Transmission Control Unit (TCU);
and
The On-Board Diagnostic (OBD) system, and any malfunctions detected
by the OBD system
Additionally, the engine long block warranty shall cover the engine subassembly that consists of the assembled block, crankshaft, cylinder head, camshaft, and valve train.
In our continuing efforts to assure proper performance of your
Volkswagen vehicle, your dealer will diagnose and replace the emissionsrelated components listed in this section, if necessary, at no cost to you
as long as the vehicle remains within the time and mileage limits of this
warranty extension.
This warranty extension covers only the diagnosis and replacement of the
emissions-related components listed in this section. Should you ever sell
the vehicle, this warranty extension is fully transferable to subsequent
owners.
This warranty extension will not cover:
Any damage or malfunctions caused by installation of emissions-related
parts not certified by the U.S. EPA or California Air Resources Board
(CARB), including such damage or malfunction to parts needed for
proper diagnosis of a covered part; or
Damage or malfunctions caused by outside influence, such as damage
due to an accident, or vehicle misuse or neglect, but only if the damage
or malfunction is causally related to the accident or vehicle misuse.
All normal warranty provisions remain in effect. The Extended Emissions
Warranty includes parts, labour, and applicable taxes. The Extended
Emissions Warranty shall not void or supersede any existing warranty.
10
Customer Notices
For vehicles that do not receive the emissions modification, certain
emissions-related replacement and repair parts may at some point no
longer be available from Volkswagen. Accordingly, in the future, if your
unmodified vehicle requires maintenance and repairs of the emissions
system, we may need to perform the approved emissions modification
first, including installing the Engine Control Unit (ECU) associated with
the approved emissions modification. This may lead to changes to your
vehicle’s operation or performance resulting from those modifications
as discussed in this booklet.
If the vehicle has been modified by the customer prior to receiving the
emissions modification in a manner that may yield a non-compliant
emissions system (for example, removal of a catalyst, installation of
parts that impact emissions or emissions-related parts, or modifications
to the ECU or computer software of the vehicle), Volkswagen may not
be able to perform the emissions modification until the customer
corrects such modification.
Transferability
This extended emissions warranty is fully transferable to subsequent
owners.
