Hello all, this is my first post. I've tried to search the forums, but haven't found an answer to my problem.
Two days ago my right fog light failed. Then the left headlight. Then the left fog and the right headlight. Now the passing lights will work, but the high beams won't stay on. So essentially I have a right fog and passing lights. Also, the dash light for my rear defrost isn't working (not sure if the elements work, it's summer so I have nothing to defrost).
All the fuses appear to be fine. The sidemarkers work, as well as my daytime running light, tail, and brake lights.
I'm guessing that there is something wrong between my euro switch and the multi switch because the passing lights will still work.
Any thoughts?
Any thoughts?
