Hey I have been a long time listener, first time caller. I started a thread on vortex yesterday because I could not post on this forum till I got approved. So Sorry to cross forums but I need help!
Here is the thread
http://forums.vwvortex.com/showthre...n-t-want-to-start-run&p=99687097#post99687097
Here is the first post.
I have a 2000 Jetta TDI and I have had it for about a week and it worked great the 600+ miles since I got it. Then one day, I parked it in normal running condition then later that night I went to drive home and it starts but rough(thinking I need to maybe check the glow plug system, nothing new) I start to drive and it stalls out. I try it again and it's a bit harder to start so I try to give it some juice but there is no effect and it stalls out again. A third time and it doesn't start till I crank it and cycle the glow plugs a few more times, then there's no chance it will run and I can't even play with the throttle. I bleed the fuel lines and they are spraying fuel but not as much as I would like UNTIL the engine starts running a bit(after many long cranks). There is fuel in the clear line after the filter(filter is new) so air in the fuel lines do not seem to be my problem. Next day I start playing with it again and same issues, but it actually started quicker the morning after then it did the last try the night before I put a jump wire from the B+ to the stop solenoid and no difference. I was holding the cable on the solenoid as my friend was cranking the motor and the cable slipped off the stop solenoid and grounded out at the fuel pump body, sparks flew... engine started running and I was able to drive it around drove it home later that day, no problem. Next morning, same starting issues where it would start and die once or twice and then no chance I have some ideas as to what it could be, but really I'm clueless. I want to hear what you all might think or send me links or push me into the right diag direction to help me out. I don't have VAGcom as of now but have just ordered it...
Thanks in advance
Here is the thread
Thanks in advance
