rbjones21
Changed out the pedals and the door switches. I think it turned out good.
I learned a few things doing these.
1. The pedal replacement is easy for the most part except there is a screw holding the dead pedal that is a bit trick to get to. Also there is a tool to remove the gas pedal, but can be done with screwdriver
2. You can swap out the switches without removing the door panel. It is bit tricky to remove the plastic holding them.
If anyone has any questions let me know.
