ksing44
I have 161,000 miles and had the fix ~8000 miles ago, I got a check engine light and a P2002 code and the dealer says I have a clogged DPF. It's covered under warranty! But I think it's interesting and wanted to share with all of you.
The service writer indicated he typically sees this on the TDI cars between 150K and 200K miles. Glad I got the fix and the warranty before this happened! I changed to a mostly shorter commute the last couple of years and suspect that may have contributed.
I didn't run a scan of my own yet, but I did one at Mile:122,947 and I had Oil Ash Volume: 120 ml. So I suspect I'm around 160 ml, maybe a bit more, considering my shorter commutes this last couple of years.
One more note, the check engine light went off just before I went to the dealer. The code was stored, so the dealer still had the information and I could see it on my P3Cars gauge. I cleared the fault twice in the past, because I was away on vacation and hated looking at the check engine light. When it came on again at home, I scheduled the appointment at the dealer. Then, on Sunday before my appointment on Monday, the light went off on it's own.
