Where did you put the bolt to hold it closed? Can you post a photo if possible?I just found a bolt i had lying around that was the right size and jamb it in the to hold it up and reinstall it.
I removed it and force closed the flap and used a bolt to hold it in the closed position.
i will get one this weekend. never posted pics on this site yet. is it easy?Where did you put the bolt to hold it closed? Can you post a photo if possible?
