Newgene
I plan to check it again this weekend. I am assuming all of the dual fan systems require both fans to be running when the AC is on. If so, I can also check that quickly this week.A one minute delay is probably about normal, not a malfunction.
From what you describe on your 2009, you need to verify that your fans are running. It sounds as if one or both of your fans may be faulty.
The typical fault is a 10 to 15 minute delay for the first use of the day, then it works ok for the rest of the day. Cutting in and out, or warming up when you slow sounds as if it may be some other problem.
Also, do you think there is anything I would see on vagcom? If I ran the simple scan, would it give me an error when it hit that section?
