Leaky Injector Pump
runaway231
SE Michigan, I-96+US-23
00 nb tdi 300k
Spent the good part of an hour reading previous posts on the subject of leaky IP's, all good info, mine seems to only leak when the temp outside drops below 20 degree's F.
My car starts and runs fine but the pumps leaks from the timing cover side. When the temperature gets above freezing the leak seems to stop or nearly so. I have replaced the T-valve on the fuel filter. Anyone have any idea's on this apparent cold related fuel leak? Also, this engine is about ready for a TB change out and I would like to have a rebuilt IP on hand at that point.does anyone have any experience with Bosch reman's?
I got the link from a previous post on this, just want some feedback. Thanks.
