Reddok
- Joined
- Feb 18, 2010
- Location
- Hamilton, Ontario
- TDI
- '00 Jetta TDI 01M, '02 Jeep Liberty Renegade ALH TDI swap
The small hose goes to my heater core. Large goes to my rad.
alh crank trigger is just a four slotHey Im bugging you again on this but just wanted to confirm you used the crank as the signal wire and not pin 27 correct? Also do you know if the ALH crank trigger is a 60-2 wheel? I see thats what is on the 1.8 gassers but I am having trouble finding the info for the ALH.
Weird thats what I just did. Im gonna go tripple check my connections. ThanksSo I'm pretty sure I just spliced into the wire coming from my jeeps VSS while leaving it connected to the jeep ECU or cluster.
